garrett and precision The same??
Old Jun 5, 2004 | 01:12 PM
integramic's Avatar
Default garrett and precision The same??
I ordered a turbo from a company off here(will not name). It was suppose to be a sc61 with the works(stage 5 wheel, custom exhaust plate,..etc). I just looked at it the other day and it dose not say precision on it. They said they were waiting on it for a month from precision because it was custom. I got it now and it says garrett on it. ??
Old Jun 5, 2004 | 01:36 PM
alpha's Avatar
Default Re: garrett and precision The same?? (integramic)
You probably got Garrett's 4-bolt turbine housing instead of Precision's 5-bolt turbine housing. Is there scribing on the compressor outlet?
I have a better picture of the scribing if needed.
Old Jun 5, 2004 | 02:42 PM
integramic's Avatar
yes there is.
Old Jun 5, 2004 | 02:51 PM
alpha's Avatar
Default Re: (integramic)
What are the numbers? Is it a 4-bolt or 5-bolt turbine housing?
Old Jun 5, 2004 | 03:25 PM
integramic's Avatar
Default Re: (0x64)
It is a four bolt.
Old Jun 5, 2004 | 03:35 PM
alpha's Avatar
That's why it says Garrett. Precision uses Garrett 4-bolt turbine housings.
Old Jun 5, 2004 | 04:04 PM
integramic's Avatar
Default Re: (0x64)
says it on the inlet side also...
How can I tell if the compressor wheels are right??
Old Jun 5, 2004 | 04:13 PM
alpha's Avatar
What does the scribing say on the compressor outlet? Measure the compressor wheel inducer and exducer.
Old Jun 5, 2004 | 04:17 PM
integramic's Avatar
Default Re: (0x64)
garrett
Old Jun 5, 2004 | 04:21 PM
TurboBumblBee's Avatar
Default Re: (0x64)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 &raquo;</TD></TR><TR><TD CLASS="quote">What does the scribing say on the compressor outlet? Measure the compressor wheel inducer and exducer.</TD></TR></TABLE>
let me jump in here.. what is the inducer and exducer on turbos?? ive been tryin to find out the exact model of my precision turbo and i cant.. i wish i understand all the real technicals on the turbo sizes and things like.. can anyone explain please??
Old Jun 5, 2004 | 04:22 PM
alpha's Avatar
I mean what does the scribing on the compressor outlet say? You could also measure the compressor wheel inducer and exducer.
This is an example of Precision's scribing
Old Jun 5, 2004 | 04:26 PM
alpha's Avatar
Default Re: (Boostfedb18c1)
Measure the base of the wheel (compressor=exducer, turbine=inducer) and the tip of the wheel (compressor=inducer, turbine=exducer).
compressor wheel -
(inducer x inducer) / (exducer x exducer) (100)
turbine wheel -
(exducer x exducer) / (inducer x inducer) (100)
A: Turbine wheel, B: Bearing and seal, C: Turbo shaft, D: Exhaust turbine housing, E: Backplate, F: Compressor wheel, G: Compressor housing, H: Bearing housing, I: Inducer bore, J: Exducer bore
With Precision turbochargers you can identify them with the scribing. The only way the scribing would be wrong is if the individual assembling the turbocharger at Precision made a mistake.
Old Jun 5, 2004 | 07:34 PM
integramic's Avatar
that is what I have on mine...6152E
Old Jun 5, 2004 | 07:42 PM
alpha's Avatar
6152E is an SC61 with a T350 76 trim turbine wheel and a T04E compressor cover
Old Jun 5, 2004 | 07:50 PM
integramic's Avatar
Default Re: (0x64)
Is that the best I can get other then the sc63?
Old Jun 5, 2004 | 07:55 PM
alpha's Avatar
Allot of tuners on here seem to prefer the SC61E over the SC63E. The only other turbocharger (within that price range) I would take over that is the non ball bearing Precision GT35E.
Old Jun 5, 2004 | 08:40 PM
Default Re: (0x64)
can you tell me what turbo i have exactly??
presicion turbo
4431E
thanks
Old Jun 5, 2004 | 08:55 PM
alpha's Avatar
Replied Time to goto sleep.
Old Jun 5, 2004 | 08:59 PM
Arturbo's Avatar
Better than steak
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfedb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">can you tell me what turbo i have exactly??
presicion turbo
4431E
thanks</TD></TR></TABLE>
SC44 31=t31 turbine wheel.
Old Jun 5, 2004 | 09:02 PM
*Boostwerks*'s Avatar
Ur just all..."Precision's Little Helper" today arn't you?
Old Jun 5, 2004 | 09:09 PM
Default Re: (Bryson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">Ur just all..."Precision's Little Helper" today arn't you? </TD></TR></TABLE>
lol.. im happy i know what turbo model it is now.. turbo was bought from inline pro and i forgot...
how much better would an SC61 do over my SC44??? should i look into upgrading?
Old Jun 5, 2004 | 09:11 PM
Arturbo's Avatar
Better than steak
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfedb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">lol.. im happy i know what turbo model it is now.. turbo was bought from inline pro and i forgot...
how much better would an SC61 do over my SC44??? should i look into upgrading?</TD></TR></TABLE>
The SC44 is a good turbo. If I am not mistaken they use it with a .48AR housing? For the most part people have turbos that can already make 500whp but still want a SC61.
Old Jun 5, 2004 | 09:14 PM
Default Re: (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">
The SC44 is a good turbo. If I am not mistaken they use it with a .48AR housing? For the most part people have turbos that can already make 500whp but still want a SC61.</TD></TR></TABLE>
yes it has a .48 a/r housing... whats the a/r ??? on precisions site it says i can also be a .63 would that have been a better turbo??
im pretty sure im happy w/ this turbo for now.. once i get it dyno tuned, ill be even happier
sorry its late and another shitty saturday night (i hate rain) so im getting a crash course on definations of turbos..
Old Jun 5, 2004 | 09:29 PM
Arturbo's Avatar
Better than steak
25 Year Member
The SC44 with a .48AR works really good together on a street car. Makes things really fun...
art
Old Jun 5, 2004 | 11:07 PM
NuclearB18B's Avatar
i traded my sc61 for a sc44 and have no regrets. afterall, how can i be disappointed with quicker spool?
