FYI: Shopping list for oil feed and return lines. SAVE THIS THREAD!!
Ok, another member just PM'd me and asked the famous question about the feed and return lines. This is what I wrote back to him. THIS IS HOW I DID MY SETUP! SOme of you may choose to have the "T" mounted on the firewall, if you do this, then you WILL NEED 2 more 981604 and 2 more 300104 and you wont need 991101.
Be sure to save this post, cause we all know that this question pops up 3 times every week and not too many people put together an organized shopping list.
This is what I wrote:
Happy Boosting!
[Modified by 93LSivic, 1:58 PM 7/17/2002]
[Modified by 93LSivic, 1:59 PM 7/17/2002]
[Modified by 93LSivic, 1:12 PM 7/19/2002]
OK, I just spent a half hour putting together a shopping list for you. Keep in mind this is exactly how I did my feed/return system. I decided not to use the factory oil sensor because i went with a mechanical oil pressure gauge that runs off the feed "T" coming off the block. Also I used a union in the pan---drilled bigass hole and sealed with silicon, in this case Im giving you stratoseal p/n so you can do it right (which I didnt do--in light of getting turbo install done)
All part numbers are from amstreetrod.com ---best prices and parts are always in stock.
Feed:
1/8 nipple for block -- 991101
1/8 "T" -- 991701
1/8 to -4AN -- 981604
(2 needed) -4AN straight swivelseal hose ends -- 300104
(4 ft needed) -4AN ss hose -- 400040
For adapter to turbo you will need one of these depending on the size of the hole on the turbo itself.....
1/8 npt hole 982204 (Smaller T3's use this one I believe)
1/4 npt hole 982244 (This was the one I used for my t3t4)
Return:
Aluminum return flange found at turbocharged.com p/n is 20259.
-10AN flange side male to hose -- 824510
(2 ft needed) -10AN hose -- 400100
-10AN 45 to pan fitting -- 804610
-10AN union for tapping pan -- 981510
-10AN bluhead nut for union in pan -- 992410
Stratoseal for union (package includes 2) -- 178014
This should be all. Probably a little on the pricey side, but no one ever said going turbo is cheap!!
Feed:
1/8 "T" -- 991701
Return:
1 Post
Re: FYI: Shopping list for oil feed and return lines. SAVE THIS THREAD!! (93LSivic)
Thank you very much. No one ever replied to my post about oil feed line. This solves my prob so I can finish up.
Re: FYI: Shopping list for oil feed and return lines. SAVE THIS THREAD!! (BoOsTeD_eK)
What?? You want me to dress you every morning too????
Damn, I thought I took the pain out of the newbie oil feed/return setup question. I guess some people just need their hand held all the time.
Good list, man. I'm definitely saving it!
Sonny
Damn I though a lot of people asked me that, but you too?
They are JUST HOSES guys. Simple stuff.
You need a hose and a hose end for every end of hose you have.
Then all you need is an adapter to go from whatever fitting or hole you are trying to connect to the hose to the hose fitting.
:dookie:
:dookie:
Re: FYI: Shopping list for oil feed and return lines. SAVE THIS THREAD!! (theory48)
next trendy question....how much did this setup cost you? also, i thought the block was bspt and not npt?
Re: FYI: Shopping list for oil feed and return lines. SAVE THIS THREAD!! (GraphiteAccord)
Justin
The block is BSPT. I threaded a NPT in mine. Well when I pulled the motor and my oil lines I left some threads in the block.
I should have gotten the adapter....
Re: FYI: Shopping list for oil feed and return lines. SAVE THIS THREAD!! (Doodoo)
thanks doodoo, i'll go ahead and get the bspt fittings. Alittle comedy relief for you guys, i went to price all this stuff out yesterday, on the website listed above. Well, lol, i e-mailed them in a hurry to something of the tune of "here are these parts numbers, could you please e-mail me back prices of each part? thanks" and guesss what? they e=mailed me back promptly with the prices of each! the e-mail is following...:
Hello, you have a great website, wondering if you will e-mail me back with prices on the following part numbers you stock:
991101......... $2.33
991701..........$13.31
981604..........$2.41
300104 x 2....$6.77/ea
400040 4 ft needed...........$6.60/ft
982204............$7.16
824510............$36.88
400100............$10.10/ft
804610............$28.71
981510............$5.98
992410............$2.33
178014............$8.10
thank you for your help!
grand total is 187.55 before shipping...though, i think my dad can get stuff for jobber, so i'll look into that myself...
[Modified by GraphiteAccord, 6:14 PM 11/1/2002]
Re: FYI: Shopping list for oil feed and return lines. SAVE THIS THREAD!! (IcebergSlim)
I can get a nice full kit a bit cheaper than that.
I just got mineso i didnt have to screw with part numbers and all that . lmk if interested.
This REALLY needs to be a sticky in the FI forum, along with about a dozen other threads.
Re: FYI: Shopping list for oil feed and return lines. SAVE THIS THREAD!! (johnisenglish)
ok, went to a local muscle car shop that can get these kinds of things(stupid import places around here cant/wont or will at really dumb prices)
so i ordered it all up(some is in but some needs to be ordered)
BUT I didnt get the ALUMINUM return flange...
hmm...where to get one( i want to do it locally)
any company make one?
Re: FYI: Shopping list for oil feed and return lines. SAVE THIS THREAD!! (SiRkid)
just to keep it on top, hwere it should stay...forever....
Whats the differencegoing to be between -3 and a -4 setup?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GraphiteAccord »</TD></TR><TR><TD CLASS="quote">
I can offer the whole complete feed line kit (with the BSPT adapter), Oil return line kit and the drain flange for $ 125 shipped to you...
Here are the complete oil line kits for your turbo application,
The oil feed line kit,
The oil return line kit,
You do need to have a threaded oil drain flange for the oil return kit, most turbos comes with it, if not, I can supply you with an aluminum billet flange and gasket.
stan
stan
Re: FYI: Shopping list for oil feed and return lines. SAVE THIS THREAD!! (Flamenco-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T »</TD></TR><TR><TD CLASS="quote">
So you can supply all those fittings and hoses for $125. For a T3/T4 application. Because I just priced the list and came up with $213. Are the products you supply Earl's Fittings? If not what brand?
