FULLY BUILT with a really bad problem
Old Apr 8, 2005 | 06:08 AM
orangeturbogsr94's Avatar
Default FULLY BUILT with a really bad problem
Well I have a fully built motor lower compression sleeved and i'm running a garrett T57 and well maybe I got a little carried away and decided to run 15 PSI but still thats normal for a Built motor well by doing that I got a clicking noise after I ran it a couple of times and I dont know what it is I thought It was my valves I adjusted them it wasn't that it's comming from the #1 cylinder side
The sound comes from like where my timing belt is at and I dont think its the rod cause when I drive it fine but when idling it sounds a little bad maybe it could be the oil pump not sure
CAN SOMEONE HELP OUT
Old Apr 8, 2005 | 06:16 AM
Aggressive Racing's Avatar
Default Re: FULLY BUILT with a really bad problem (orangeturbogsr94)
I hope it's not a wrist pin....
Old Apr 8, 2005 | 06:18 AM
crispydee's Avatar
What engine is it? if its vtec it could be the LMA's... (lost motion assemblies) they hold the vtec lifters against the cam when the vtec is dissengaged and can stick making them noisey.
Old Apr 8, 2005 | 06:24 AM
underpressure02's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orangeturbogsr94 &raquo;</TD></TR><TR><TD CLASS="quote"> and well maybe I got a little carried away and decided to run 15 PSI but still thats normal for a Built motor </TD></TR></TABLE>
Were you tuned? Or did you just take a fully built motor out and boost on it b/c it is fully built and doesn't need a tune?
Old Apr 8, 2005 | 06:52 AM
Rod.'s Avatar
Default Re: FULLY BUILT with a really bad problem (underpressure02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 &raquo;</TD></TR><TR><TD CLASS="quote">
Old Apr 8, 2005 | 06:55 AM
B18C1CYA's Avatar
like stated above , was it tuned ??? if not could have broke a ring land
Old Apr 8, 2005 | 08:58 AM
platinum00's Avatar
Default Re: FULLY BUILT with a really bad problem (B18C1CYA)
15psi is nothing for a built motor, if you had it tuned, if not and start rebuilding...
Old Apr 8, 2005 | 12:58 PM
I had it tuned but not dynoed it was just street tuned but still trying to figure out what it is. I have AEM EMS and I think I'm getting rid of it for Hondata.
Old Apr 8, 2005 | 01:01 PM
platinum00's Avatar
damn man, now i feel bad for you... Street tuning should have been more than enough for those low numbers.
who built the motor, what are the clearances, etc...
Old Apr 8, 2005 | 02:43 PM
EG1.8cT68's Avatar
Don't get rid of your AEM just find someone that can tune it.
Old Apr 8, 2005 | 03:05 PM
95GSRTT
Guest
Posts: n/a
If you have a straight LS i have the same problem. My head makes a ticking noise all the time, especially when its cold. I believe its just the head out of wack and i need either another good valve adjustment or something else. And this was right after being tuned on the dyno with hondata.
I have benson sleeves/wiseco pistons/eagle rods. Its just something I live with since my vtec conversion will be done really soon here.
Old Apr 8, 2005 | 04:40 PM
beepy's Avatar
Default Re: FULLY BUILT with a really bad problem (95GSRTT)
Check for exhaust leaks. An exhaust leak from the head flange sounds like a tick.
Old Apr 8, 2005 | 04:48 PM
Frozen E's Avatar
H-T White Ops
Do a compression test. That'll more than liely tell you if you've busted a ring land or not.
Old Apr 8, 2005 | 04:55 PM
Si Shane's Avatar
Default Re: (IslandSi)
I just went through so many emotions reading this thread
Old Apr 8, 2005 | 05:07 PM
Frozen E's Avatar
H-T White Ops
Do a simple 5 minute compression check and you'll either be happy as a fly in **** or feel like you've been kicked in the nuts by an NFL fieldgoal kicker. Hope for the first one.
Old Apr 8, 2005 | 08:09 PM
joejoe1's Avatar
The exact same thing happened to me, but I had a stock bottom end. Well I kept checking my valves and head components in denial that it was the bottom end until my #1 connecting rod bolt broke off and peices of the rod blew through my block. Check the bottom end!
Old Apr 10, 2005 | 05:48 PM
Well I had my block done at bensons its sleeved with eagle rods and wiseco pistons and a little over bore. I just built it in august and now it looks like im going to put another $1,000 in it to fix cause im just gonna take it to a machine shop and they will put new bearings and fix the problem for $800 so I just rather pay that than pay double later on.
Old Apr 10, 2005 | 06:10 PM
95GSRTT
Guest
Posts: n/a
I take it you got it done by earl? Have you talked to him at all? I would THINK he would try to help you out, if it was just done and still screwing up.
Old Apr 11, 2005 | 05:37 AM
Well by any chance do you have somewhere I could contact him because I lost hes e-mail and phone#.
Old Apr 11, 2005 | 05:56 AM
Si Shane's Avatar
... search... post bodies.... recent content..... creator: "earl"
"Your serach returned 196 ways to contact earl"
Old Apr 11, 2005 | 11:54 AM
warrick's Avatar
was your car tuned up to 15 psi? cause if you were tuned to 6psi and decided that a "tune is a tune", then I'd like to see pictures of your motor once it's stripped apart.
I'll trade you straight up for a hondata s200 with boost. I'll even pay shipping both ways.
Old Apr 11, 2005 | 03:28 PM
nfn15037's Avatar
Default Re: FULLY BUILT with a really bad problem (warrick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warrick &raquo;</TD></TR><TR><TD CLASS="quote">was your car tuned up to 15 psi? cause if you were tuned to 6psi and decided that a "tune is a tune", then I'd like to see pictures of your motor once it's stripped apart.
I'll trade you straight up for a hondata s200 with boost. I'll even pay shipping both ways.</TD></TR></TABLE>
Aww man beat me to it!! LOL
Old Apr 11, 2005 | 03:57 PM
VanHonda's Avatar
Default Re: FULLY BUILT with a really bad problem (nfn15037)
Any chance it could be piston slap? I have seen several sets of wiseco pistons that slap a little, but it should go away when warm. Just a possibility.
Old Apr 11, 2005 | 04:17 PM
Antilag's Avatar
Default Re: FULLY BUILT with a really bad problem (VanHonda)
what kind of turbo manifold are you running? look for a crack in the exhaust.
Old Apr 11, 2005 | 06:30 PM
turbodohcsi's Avatar
do the old indian trick and put a screwdriver, or metal pole on different spots of the motor and see if you can locate the tick. i would suggest doing a compression test. the wisecos have pretty damn thick rings, and ringlans so i doubt its the pistons, unless you did boost 15lbs on a 6lbs tune. maybe your pistons are hitting your oil squirters if you have any. maybe it is just piston slap. i doubt its a bent valve cause the deep *** valve reliefs in the wiseco's. i hope you got the wrist pin locks in the groove all the way, if not i can show you pictures of what happens when you dont....... or when you use spiral locks. but oh well, i put my 2 in, so good luck
