fully built gsr..need help
Old Jan 3, 2009 | 04:16 PM
jdmb16turbo's Avatar
Default fully built gsr..need help
ok i got a motor off of a guy its a fullu built gsr below is whats done to it....
b18c1 darton open deck 85mm sleeves
-crower crank makes it alomost a 2.2L
-Custom Pauter rods
-wiesco pistons 8:5 compression
-arp head studs
-cometic headgasket
-01 gsr head
-port and polished intake and exhaust side
-Ferrera 1mm oversize valves
-3angle valve job
-crower dual valve springs
-skunk2 titanium retainers
-Crower stage 3 cams 272's
-Aem cam gears
the problem im getting is all my cylinders are between 130-135 i was wondering why its so low for a 9:1 compression motor it seems to its 8:5:1 right any help would be great thanks.but when we did the test it wasnt at wide open throttle we where just turning it over
Old Jan 3, 2009 | 04:25 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: fully built gsr..need help
well since they are even thats a good thing. go back make sure the battery is good and charged, and do it with the throttle wide open. and if the results are the same, leakdown it.
Old Jan 3, 2009 | 04:34 PM
how do you do a leakdown test
Old Jan 3, 2009 | 05:13 PM
can anyone else help me out on how to do a leakdown test or do i take it to a shop. i just seen a small gas leak from a fuel line i gotta fix
Old Jan 3, 2009 | 08:27 PM
tegman23's Avatar
You can do it your self, you can buy one at an automotive store.....
Old Jan 4, 2009 | 06:19 PM
any other answers?if they where the 9:1 cp pistons what would make every cylinder be the same?130-135 in each cylinder is low for 9:1
Old Jan 4, 2009 | 07:22 PM
slow96coupe's Avatar
thought you had wiseco pistons?? why now are you saying cp?
Old Jan 4, 2009 | 07:36 PM
i was puttin cp for compression my bad i do have wiseco pistons.but the guy said they where 9:1 and that comprssion is low for them
Old Jan 5, 2009 | 04:20 AM
blinx9900's Avatar
one step at a time tiger, why don't you first do your compression check PROPERLY like the first post asks then worry about leak down. honda-tech will be right here when you get back...
Old Jan 5, 2009 | 05:49 AM
96 GSR-T's Avatar
Is this a nitrous motor or a boosted motor? 85.5mm bore is living dangerously with boost.
Old Jan 5, 2009 | 06:14 AM
boosted...we redone the compression wot and its still the same
Old Jan 5, 2009 | 07:04 AM
96 GSR-T's Avatar
85.5mm bore is too much for a boosted motor, the area between the sleeves is paper thin and you will more than likely have headgasket issues and you could possibly even crack a sleeve. Do a leakdown test and see what happens, if the motor has been boosted already I would personally be very nervous pushing it, buying a boosted used motor is already fishy but one with an 85.5mm bore and using it reliably (sp?) is crazy IMO
And I suspect a Stg3 Cam with +1mm Oversize is very close on the V2V clearances, I would be careful of that, those big cams are probably going to hurt your boosted motor in terms of power.
Old Jan 5, 2009 | 07:18 AM
the tat had it before me made 650 plus if its gonna be a problem i ll just put the stock cams in it.im pretty sure its gonna be hard to crack a sleeve
Old Jan 5, 2009 | 07:24 AM
its 85mm and 8:5 pistons just got off the phone with the guy
Old Jan 5, 2009 | 07:28 AM
updated the info from the guy i got it from
Old Jan 5, 2009 | 04:23 PM
blinx9900's Avatar
Honestly my 8.3:1 motor makes 135psi across all four, it makes 340whp at 12psi on 91 octane, i never thought it was an issue, i still don't. I don't think you have any problems...
whitaker_1991
25
Sep 28, 2009 02:38 AM
408wdy
10
Jul 13, 2008 09:10 PM
Rob1242
Apr 8, 2005 04:19 AM
