full race stage 3 kit...
Old Jan 4, 2007 | 06:50 PM
snaileg's Avatar
Default full race stage 3 kit...
do you guys think the full race stage 3 kit with the t67 will be to laggy on a ls motor with a piston/rod setup planning on running about 20psi of boost still...
Modified by snaileg at 10:10 PM 1/7/2007
Old Jan 4, 2007 | 07:11 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: full race stage 3 kit... (snaileg)
t3t67ho with the .82 hot side on a stock crank'd b16 stage 3. it is a little laggy, but when it hits, instant tire smoke.
Old Jan 4, 2007 | 07:13 PM
HamiltonRex's Avatar
Default Re: full race stage 3 kit... (boostedcivicsir)
so well its spooling.. The car with the smaller turbo will hook up and have a gradual powerband and pull away, and then as soon as you make power it will spin.
Dude, go for a HP # not a boost #, want 400hp? Get something that will make you 400hp, you can overkill it a bit, but you dont need a 42R for 500hp (just using it as an example).
You want to make sure that your using the turbo efficently.
Old Jan 4, 2007 | 07:21 PM
Mr. Badwrench
Default Re: full race stage 3 kit... (HamiltonRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">so well its spooling.. The car with the smaller turbo will hook up and have a gradual powerband and pull away, and then as soon as you make power it will spin.
You want to make sure that your using the turbo efficently.</TD></TR></TABLE>
well put. i got my turbo to grow into, but trying to run sfwd it isnt enough, but i will still run it anyway.
Old Jan 4, 2007 | 07:24 PM
numba1's Avatar
FULLRACE kit! you a balla! lag who cares you got money.
Old Jan 4, 2007 | 07:37 PM
Boner_Ben's Avatar
Default Re: full race stage 3 kit... (numba1)
Just get some valve springs and its all good. I have a t3/t67 on a 1.6 liter and its not that bad just have to rev it out to stay in boost between shifts.
Old Jan 4, 2007 | 11:10 PM
Speed Infliction's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numba1 &raquo;</TD></TR><TR><TD CLASS="quote">FULLRACE kit! you a balla! lag who cares you got money.</TD></TR></TABLE>
lol
Old Jan 5, 2007 | 09:04 AM
Full-Race Geoff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snaileg &raquo;</TD></TR><TR><TD CLASS="quote">do you guys think the full race stage 3 kit with the pt67 will be to laggy on a ls motor with a piston/rod setup planning on running about 20psi of boost still...</TD></TR></TABLE>
honestly, how much power are you looking to make? A lot of people (in my opinion) tend to use too large of a turbo for their application and while the car might be FAST, it isnt FUN. I prefer fast AND fun.
A stage 1 kit is a great option, as is the stage 2GT. both work REALLY well on an LS engine and can offer huige powerbands. The stage 1 can make just shy of 500whp, while the stage2GT can make close to 550 with the right top end setup
out of curiosity, why dont you want to use a VTEC head? VTEC makes a huge shift in the powerband, really is worth considering
Old Jan 5, 2007 | 01:52 PM
snaileg's Avatar
the stage 3 kit was a steal price and its not the high output turbo and i have a b16 head about to get built and a full head job but wont be done until mid march so i was just wondering if there will be to much lag if im revving my motor to 8k
Old Jan 5, 2007 | 08:04 PM
numba1's Avatar
Default Re: full race stage 3 kit... (Speed Infliction)
FULLRACE!, you a BALLA, "everything else is HALF fast" That says it all. Plus you got MONEY.
Old Jan 6, 2007 | 05:32 PM
Boosted B6teen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numba1 &raquo;</TD></TR><TR><TD CLASS="quote">FULLRACE!, you a BALLA, "everything else is HALF fast" That says it all. Plus you got MONEY. </TD></TR></TABLE>
Ok we all know he is a baller now, since youve said it twice. Lay off the crack pipe
Old Jan 6, 2007 | 06:10 PM
b18sihatch's Avatar
Im going to be running the Stage 3GT on my b16a setup. i have the upgraded 20x3x11 Full race backdoor intercooler (talk about baller setup)
i have almost the exact same build they show on the full race website with the 81.5mm bore 650whp stg 3gt setup.
definitly like one of the other post said, lag? who cares? i plan on using my car as a highway race.
ls transmission,lsd,pfispeed traction bar,stag 3 clutch,lightweight flywheel,yada tada
but right now my clutch setup is good for 450whp with it, and i am building the head, right now the head is ported & polished with 5 angle valve job, plan on building it all up..
major major project
full race is the way to go
Old Jan 6, 2007 | 07:01 PM
Default Re: full race stage 3 kit... (b18sihatch)
He just dyno'd it tonight and made very good power on it and it spooled up good
Old Jan 7, 2007 | 09:10 PM
snaileg's Avatar
got it dynoed today put out 372whp and 280 torque on 18-20psi couldnt tell how much boost it was running because gauge was going retarded and this was on pump gas... driving on the streets if your out of boost and you get on it feels like its going but then at around 5k-5.5k it feels the most laggy then after 5.5k it pulls very hard... i think if we would push the car a little bit harder with some advancement it could of hit 400 or shy of 400whp
Old Jan 8, 2007 | 06:36 AM
b18sihatch's Avatar
Default Re: (snaileg)
isnt that kinda low whp for the ammount of PSI you are pushing?
is it a complete full race turbo kit?
Old Jan 8, 2007 | 12:26 PM
snaileg's Avatar
Default Re: (b18sihatch)
no its not to low at all because with added timing i could of got about 390ish whp and plus my pistons are 8:5:1 compression so that is pretty low also but i decided to take out timing so it would be safer but over all i am very happy and ls/vtec is coming in about 2-3 weeks im hoping to hit 450whp on less boost levels also
Old Jan 8, 2007 | 01:42 PM
Boostfed's Avatar
New User
Default Re: full race stage 3 kit... (Boosted B6teen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted B6teen &raquo;</TD></TR><TR><TD CLASS="quote">
Ok we all know he is a baller now, since youve said it twice. Lay off the crack pipe </TD></TR></TABLE>
Nah Stan isn't on crack BUT I think there is more than just ink in his Tatoo needles
Old Jan 9, 2007 | 05:45 PM
numba1's Avatar
Default Re: full race stage 3 kit... (Boostfed.com)
awh, terry you found me out.
Streetreaper
Feb 7, 2007 07:39 PM
Full-Race Geoff
Dec 18, 2004 09:58 AM
BlueTeg01
Jul 21, 2004 01:03 PM
