full race stage 1 ac gt kit
i was looking at this kit and consider getting it but i have a couple question on the kit is ac compatible but is it powersteering compatible? whats ur thoughts about the kit?
Thanks in advance
Thanks in advance
Re: full race stage 1 ac gt kit (phan222001)
it is power steering compatible, you just have to trim the power steering bracket. email us at tech@full-race.com and we can send you detailed pics.
the stage 1GT AC kit is one of the best available, it will provide almost instant spool, support up to 350whp on a 100% stock engine and is a great daily driver setup. email me at geoff@full-race.com if you have any questions
Another one..
Pic of the powersteeringbracket beeing trimmed.
Not good ones but u get the Idea.
Just remove the rust and repaint it.
Andreas.
Re: (Full-Race Geoff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full-Race Geoff »</TD></TR><TR><TD CLASS="quote">thanks for the pics andreas</TD></TR></TABLE>
No problem Geoff
No problem Geoff
Re: (evans_art)
I had a FR AC kit on my EG. PS did fit with slight trimming of the upper bracket. A slim fan is needed to be ran on the condenser though. Atec posted pics of a FR prostreet manifold, which is not quite the same as the AC kit. My turbo was at a bit more of an angle to clear the compressor and the WG is positioned off to the side. Overall, I could of not been happier with the kit!
Re: (turbotommy)
Here is a pic with a Rad fan insalled and the con fan changed to a pusher an mounted on the other side...the orange sticker gives it away.
Also...if screens aren't for you, and you would prefer a filter, an intake tube will have to be constructed; because there is no way a filter will fit the turbo with the larger rad and rad fan...as you can see the FAL slim fan even had to be "modified" aka hacked to work without rubbing in this set up.
