full boost in 1st?
Old Dec 22, 2004 | 09:39 AM
scartail's Avatar
Default full boost in 1st?
can some estimate when i'm supposed to be at full boost at what gear?
i've got supposely a t3/t04b on my stock b18b, stock integra. 2.5" dp and a log style manifold.. my wg is set at 5 psi...
I've read the post...
https://honda-tech.com/zerothread?id=984594 but I dont' completely grasp everything..
thanks.
Old Dec 22, 2004 | 10:41 AM
_entropy's Avatar
Default Re: full boost in 1st? (scartail)
For a smallish T3/TO4B I would expect 5 psi at about 3500-4000 RPM's. First gear does not place as much load on the motor (motor does not have to work as hard to accelerate) so you do not make boost as quickly, and lots of times do not make full boost in first gear.
Old Dec 22, 2004 | 12:34 PM
mildly.interesting's Avatar
T3/T4 .63/.60 on a 8:5.1 B18a, and I don't make full spool (14 lbs) till the top of 3rd...
Old Dec 22, 2004 | 12:52 PM
PM-Performance's Avatar
Default Re: full boost in 1st? (@lbert)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by @lbert &raquo;</TD></TR><TR><TD CLASS="quote">First gear does not place as much load on the motor (motor does not have to work as hard to accelerate) so you do not make boost as quickly, and lots of times do not make full boost in first gear.</TD></TR></TABLE>
ive noticed that wayyy too many times.
Old Dec 22, 2004 | 01:11 PM
m R g S r's Avatar
Default Re: full boost in 1st? (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">
ive noticed that wayyy too many times. </TD></TR></TABLE>
Which is also a good thing, becase you know about boosted honda's and wheel spin. . .
Old Dec 22, 2004 | 01:13 PM
Default Re: full boost in 1st? (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">
Which is also a good thing, becase you know about boosted honda's and wheel spin. . .</TD></TR></TABLE>
ive never experienced wheel spin , whats that? lol
Old Dec 22, 2004 | 01:39 PM
Blackack26's Avatar
ive never experienced wheel spin , whats that? lol </TD></TR></TABLE>
hahaha.... I've noticed 1'st is mostly used for getting the turbo spinning, so it's ready for second gear
Old Dec 22, 2004 | 01:43 PM
BlackT5's Avatar
Default Re: full boost in 1st? (Blackack26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blackack26 &raquo;</TD></TR><TR><TD CLASS="quote">
hahaha.... I've noticed 1'st is mostly used for getting the turbo spinning, so it's ready for second gear </TD></TR></TABLE>
Sounds like you need to turn the boost up
Old Dec 22, 2004 | 01:53 PM
96-EJ6 B18C's Avatar
Default Re: full boost in 1st? (BlackT5)
Wheel spin in a turbo honda naaaahhhhhh never.
I have a 60 trim T3 and I only make a few psi in first and have full boost (.8 BAR) by 3800 in second (if the tires will hook).
Old Dec 22, 2004 | 02:41 PM
scartail's Avatar
thank you everyone for responding... you're giving all good feedback...
how about getting any positive pressure? i see it gets somewhat close.. but doesnt' ever exceed into positive pressure.
Old Dec 22, 2004 | 02:42 PM
_entropy's Avatar
Default Re: (scartail)
Are you saying it never leaves vacuum when you're in first gear?
Old Dec 22, 2004 | 03:22 PM
scartail's Avatar
Default Re: (@lbert)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by @lbert &raquo;</TD></TR><TR><TD CLASS="quote">Are you saying it never leaves vacuum when you're in first gear?</TD></TR></TABLE>
Yes... even at over 5K... I'm thinking my bov maybe leaking.. im going to take it off... and run without it... I was told 5 psi won't hurt anything...
Old Dec 22, 2004 | 04:04 PM
its harder to build boost in 1st gear, but not imposible. just might not build full boost. if you arent building any, you have some probs that need to be looked into or youre turbo is too big
Old Dec 23, 2004 | 02:49 PM
scartail's Avatar
Default Re: (itr206)
I figured it out!!! Awesome... I can get full boost in 1st gear (only 5 psi, though)...
I took my bov off and ran without it... what I thought was bov flutter was actually compressor surge... Then I mounted a bov that I pulled out of a volvo... Anyway... it feels good! I took the first bov apart and found it didn't used a diaphragm and no vacuum can hold the bov open... POS!... Anyway... I was so impressed with the volvo bov... I was at the junkyard to get some clips for some DSM injectors... I decided to grab another one... Clips and bov for 10 bux... I'm stoked...
LSVtechnologytur...
Nov 18, 2004 11:22 AM
btownteg
Nov 1, 2004 08:22 PM
boost fed ls
Sep 28, 2003 02:54 PM
Ivan
Sep 20, 2002 10:39 AM
92HB_HB
Mar 10, 2002 06:32 PM
