Fuel System Help!!!
Old Dec 13, 2011 | 08:59 AM
ILLuSiv3's Avatar
Default Fuel System Help!!!
So im done with my boosted LS/Vtec Build, everything except fuel. I have 2 walbro 255s at the moment and Bosch 1600s with a stock fuel rail. I have heard of a few different pumps and setups but I have no idea which setup to use, even if I should get rid of the walbros and go with another setup. Help people!!! what are your setups? and give me advice!
Old Dec 13, 2011 | 02:07 PM
boostedEF91's Avatar
Default Re: Fuel System Help!!!
It depends on how much power you want. One pump is fine if your keeping it around 500hp. If going for 600+ you could consider a Bosch 044 inline or a walbro 255 inline Along with your 255 intank as well.
Old Dec 13, 2011 | 02:08 PM
h22apwrd95's Avatar
What fuel are you using? HP goals? You running the Full Blown dual hanger?
Old Dec 13, 2011 | 05:09 PM
92Snatch's Avatar
I sumped my factory tank w/a Inline pump, -8feed, -6 return, filter before the pump and filter before the rail (diff micron) and a boost reference FPR. Best thing with the stock tank sumped instead of a fuel cell is my fuel gauge still works!!! lol. As asked before though...what fuel are u using and what's up HP goal? I'd ur going E85 u will need bigger lines if u plan on making more HP
Old Dec 14, 2011 | 03:11 AM
ILLuSiv3's Avatar
i want to make 500whp on pump and I wanna make like 600-650 on Race Gas
Old Dec 14, 2011 | 03:12 AM
ILLuSiv3's Avatar
And no im not running the Dual Hanger...im thinkin about using the Walbro 255 in tank and Bosch 044 inline
Old Dec 14, 2011 | 03:13 AM
ILLuSiv3's Avatar
im also debating if I should go with a PTE 6262 or a 6265 turbo...any advice on that? remember 500-550whp on pump
Old Dec 14, 2011 | 07:42 AM
DA 4 Lyfe's Avatar
Alot of power for 93 pump gas but it can be made but most likely around 18-20 psi depending on your motor build. Is E85 available to you? If so I would give that a try.
Anyway 6262 and 6265 are both good turbos. If your only looking for 650 I would say the 6262 with a .82ar because of the better spool time and alot of people had good luck with the 6262s on the street. I would only run the 6265 if you have a twin scroll to help with the spool and make a little more power.
Old Dec 14, 2011 | 08:08 AM
ILLuSiv3's Avatar
I dont know the first thing about E85...The Shodan advised me to go with the 6265 .62A/R
Adinfinitum
Apr 14, 2008 12:07 PM
1FastCoupe
Apr 15, 2005 01:56 PM
servion
Sep 17, 2004 12:29 PM
Huee
Mar 12, 2004 10:01 PM
Teluan
Sep 4, 2001 08:56 PM
