fuel rails
i am gonna have -10 an feed fuel lines on my upcoming project and was wondering if there was a fuel rail made for the b16 head that has this fitting with a -6 an return fitting. or is this going to have to be custom made? thanks for any help in advance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by username taken »</TD></TR><TR><TD CLASS="quote">about 650+
Haha, yeah, contact Stan @ Fast-Turbo [Flamenco-T] and ask him...he's the guy to see for fuel lines/fittings and that sort of stuff. If i'm not mistaken, the AEM rails only have an ID of 1/2" [-8AN] so you're going to need to find a rail with at least a 5/8" ID to have the need to run a -10AN feed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicross »</TD></TR><TR><TD CLASS="quote">AN8 has an ID of 7/16.
AN10 ID is 9/16.</TD></TR></TABLE>
I thought that -#AN meant #/16" ID....
AN size is basically the OD of a hard aluminum line.
So an 8 AN has an OD of 1/2" in an aluminum hard line, and an ID of 7/16.
Are you going to run braided stainless all the way from the tank? I can save you a ton of money if you run an aluminum hard line from the tank to the firewall.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ERL Performance »</TD></TR><TR><TD CLASS="quote">Ours are set-up like most for a -8an
[]http://www.erlperformance.com/images/Honda-Fuel-Rail-Brochure-30.jpg[/img]</TD></TR></TABLE>
Aren't there rules saying you can't ***** the **** out of your products on h-t like this?
this is like the 5th thread i've seen you post your **** in...
[]http://www.erlperformance.com/images/Honda-Fuel-Rail-Brochure-30.jpg[/img]</TD></TR></TABLE>Aren't there rules saying you can't ***** the **** out of your products on h-t like this?
Wilson Manifolds sells 11/16" ID fuel rail stock for custom applications.
http://www.wilsonmanifolds.com....html
I think the str rail has one of if not the largest bore available in a b-series rail, plus they are one of the most affordable. AN adapter fittings make using almost any size hose simple. Same goes for the return fitting out of the fpr.
try the edelbrock fuel rail http://www.summitracing.com they have a 5/8 id on the inlet check it out.
TeamCracka
Apr 28, 2004 06:55 AM
R6Elmo
Oct 2, 2003 08:09 PM
