Fuel pump capacity for turbo?
Old Feb 6, 2002 | 12:47 AM
REX VT's Avatar
Default Fuel pump capacity for turbo?
Hello I have questions regarding the stock fuel pump in a turbo environment
1. Is the stock 1991 CRX SiR fuel pump big enough to deliver at least 120 lb/hr?
2. Can anyone tell me if the 5th gen Civic VTi is similar to the CRX SiR's??
My calculations:
(taken from the info in sport compact magazine)
http://download.tripodnet.nl:81/REX_...g/08-turbo.jpg
Injector size=
expected hp: 240 @ the crank
BSFC= 0,55
expected hp x BSFC
number of injectors
240x0,55= 132/4 = 33 lb/hr
I want to use Prelude VTEC injectors since they plug right in and deliver 310cc/min (29,52 lb/hr)
Fuel pump size=
injector size x number of injectors=
29,52 lb/hr x 4 = 120 lb/hr
[Modified by REX VT, 9:49 AM 2/6/2002]
Old Feb 6, 2002 | 02:02 AM
Giuseppe's Avatar
Default Re: Fuel pump capacity for turbo? (REX VT)
im assuming youre referring to the 92-95 H22 injectors
which are rated at 345cc so that will change your calculations....
hth
Old Feb 6, 2002 | 02:20 AM
REX VT's Avatar
Default Re: Fuel pump capacity for turbo? (Giuseppe)
Are you absolutely, without doubt, 100% sure?
This is also what I found in the 1992-1996 Prelude workshopmanual:
engine: F22a1, H23a1, H23a2
255-305Kpa = 2,55-3,05 kg/cm2
engine: F20a4, F22a2
245-285Kpa = 2,45-2,85 kg/cm2
Resistance= 5-7 Ohm
Old Feb 6, 2002 | 02:29 AM
Giuseppe's Avatar
https://honda-tech.com/zerothread?id=125005
specifically H22si's comment,
and.
sgT confirmed this to me also...hth..
EDIT: btw fyi i have the 92-95 lude injectors too. theyre a nice cheap upgrade
as opposed to the RC injectors...
they're yet to be installed
[Modified by Giuseppe, 11:32 AM 2/6/2002]
Old Feb 6, 2002 | 02:45 AM
REX VT's Avatar
mmm 345 cc is a little big .. or not?
Isn't it better to put more pressure onto the fuel rail and squeesh out max 40% extra fuel?
Old Feb 6, 2002 | 03:01 AM
Giuseppe's Avatar
heres another link: https://honda-tech.com/zerothread?id=121009
it really depends on your setup: pump, fmu..etc etc..
i cant give u a definite response:but i have a 1st gen b16a
and will be using the above mentioned injectors for my
application...hth
Old Feb 6, 2002 | 04:28 AM
REX VT's Avatar
330cc/min with 43 psi pressure.. howmuch psi on stock b16a1 pump? Can't find it anywhere in CRX SiR workshopmanual
90civicgsr
Feb 7, 2008 06:17 AM
b18-c-rx
Dec 26, 2004 10:44 PM
sircrxracer
Nov 15, 2003 01:34 AM
goofball123321
Sep 16, 2003 04:01 AM
