Fuel Pump
Old May 16, 2003 | 05:03 AM
boostedsi1's Avatar
Default Fuel Pump
What is the best performing fuel pump that doesn't make a high pitch wining noise?
Thanks.
Old May 16, 2003 | 05:05 AM
siis2fast's Avatar
Default Re: Fuel Pump (boostedsi1)
dont get the bosche
anyhting under a 1/4 tank and that motha is LOUD. like its back there beggin you for more gas. not to mention its about 1/3 bigger than the walbaro
Old May 16, 2003 | 06:21 AM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedsi1 &raquo;</TD></TR><TR><TD CLASS="quote">What is the best performing fuel pump that doesn't make a high pitch wining noise?
Thanks.</TD></TR></TABLE>
Depends on the intended purpose of the pump. High pressure or high volume?
Holley/walbro seem to work good
Old May 16, 2003 | 06:37 AM
Tony Starks's Avatar
Default Re: Fuel Pump (b16ahybrid)
I like my walbro.
Old May 16, 2003 | 09:06 AM
boostedsi1's Avatar
Default Re: Fuel Pump (Tony Starks)
I don't know which I need for sure. I'm either going to rund an E-manage or V-afc. Which would I use for each possibe senario? Thanks.
Old May 16, 2003 | 09:12 AM
Blue-Civic-Hybrid's Avatar
Loved
I am currently running a Walhbro 255 pump...I plan on getting either a Bosch or a MSD intank pump eventually..
Old May 16, 2003 | 04:32 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedsi1 &raquo;</TD></TR><TR><TD CLASS="quote">I don't know which I need for sure. I'm either going to rund an E-manage or V-afc. Which would I use for each possibe senario? Thanks.</TD></TR></TABLE>
Just the regular 255lph high flow fuel pump will suffice. You would only need a high pressure fuel pump if you were using a fmu set-up
Old May 16, 2003 | 06:25 PM
wzcb08's Avatar
What if you use an FMU with a high flow fuel pump instead of a high pressure? Is there anything negative about using those together. I am still trying to find out why the heck my car is running so lean on a fmu setup.
Old May 17, 2003 | 02:05 PM
b16ahybrid's Avatar
Default Re: Fuel Pump (wzcb08)
Yeah the high pressure pump is designed for higher pressures created by the fmu. The high flow just flows more at normal fuel pressures. The high pressure pump will run at higher fuel pressures
Old May 17, 2003 | 02:42 PM
Lei Siew Long's Avatar
Do Not get an MSD intank pump because it is annoyingly loud. the Bosch Intank pump is nice and quiet (when there is more than half a tank)
W O T
Jun 6, 2006 11:48 AM
FmXRider991
Oct 5, 2004 09:34 AM
Ricey McRicerton
Dec 12, 2003 01:28 PM
GSRwBOOST
Mar 13, 2002 09:22 PM
Lei Siew Long
Feb 4, 2002 06:49 PM
