fuel pump...
Old Jan 30, 2003 | 11:58 PM
CM-R's Avatar
Default fuel pump...
Guys... Would running out of gas in your car make a walbro fuel pump go bad or break? My little brother did this to his car and he now has problems starting his car when it sits for a couple of hours..It makes this bog noise for the first try then the second try at starting it works fine..could the injectors be clogged?..any info would be good
Old Jan 31, 2003 | 12:43 AM
paulzy's Avatar
Default Re: fuel pump... (CM-R)
yes it will...it makes the pump work harder and heaat up way faster. fuel pumps and heat don't mix. They break easily that way
Old Jan 31, 2003 | 01:20 AM
Tofurky's Avatar
yeah actually.. haven't you noticed when low on gas that the pump gets signifigantly louder?
it's working it's pants off to get that fuel outta there.
Old Jan 31, 2003 | 08:33 AM
gtcali's Avatar
Default Re: fuel pump... (1320development)
...fuel pumps and heat don't mix. They break easily that way
So should I put my inline pump in the engine bay or by the tank. Or engine bay heat doesn't make a difference.
Old Feb 1, 2003 | 01:05 PM
CM-R's Avatar
Default Re: fuel pump... (gtcali)
so guys, what kind of walbro fuel pump do you recommend for all motor making about 170 whp and 122 tq? plus later my bro is going to slap on a 75 wet shot NX kit...this is on a b18c1 in a 96 hatchback....thanks for any info..
Old Feb 1, 2003 | 03:40 PM
Tofurky's Avatar
your inline pump will be fine in the engine bay
Old Feb 2, 2003 | 10:46 AM
CM-R's Avatar
Default Re: fuel pump... (Ruckus138)
Where can i get a intank fuel pump for my brothers setup??
Old Feb 2, 2003 | 06:34 PM
CM-R's Avatar
come on guys i need the info real bad....
Old Feb 2, 2003 | 06:40 PM
ekb18c's Avatar
You can buy it from b18bturbo (viren). I believe he can still get some kick a$$ deals on the walbro pumps..
Old Feb 2, 2003 | 06:45 PM
CM-R's Avatar
Default Re: fuel pump... (ekb18c)
thanks for the info
j.bro
Honda Civic (2001 - 2005)
Jan 8, 2013 02:35 PM
airmaxbri
Mar 29, 2010 11:44 AM
lmananT
Jun 4, 2008 10:56 PM
GSR_Hacker
Jul 8, 2002 06:50 PM
