fuel problem
Old Jun 25, 2010 | 10:59 PM
91lsteg's Avatar
Default fuel problem
ok im boosting my 90 wagonvan
has d16y motor
50 trim
450s (dont need box)
problem!!!!!
i had the wagon runing with oem injectors. 5 mins b4 all this
i was told that the only way 2 get injectors that dont need the resistor box to work is 2 splice all 4red wires 2 the 1yellow wire, did this and then i took the 450s put them in and there not spraying, i cant hear the fuel pump prime now either, not geting fuel at the rail now also. what is the prob??????
Old Jun 26, 2010 | 03:29 AM
DUDMD's Avatar
Default Re: fuel problem
why not get low resistance injectors in the first place?
but yeah, cutting off all the wires off the resistor box wiring and soldering them together should work. 5 wires total all together.
Use a volt meter to check for voltage @ the injector plug to see if you're getting power to the injectors.
Old Jun 26, 2010 | 04:17 AM
th3pwn3r's Avatar
People run DSM injectors because they're pretty much free. Anyhow, I agree with the rest of your post.
Old Jun 26, 2010 | 08:24 AM
91lsteg's Avatar
thanks guys. yeah the reason im using these injectors is for this reason only(i already had them)
im trying 2 get a set of dsm 440s now.
what should the voltage be at the injector clip. 12v? or lower? and at the 1st ign stage?
thank you guy
Old Jun 26, 2010 | 02:56 PM
91lsteg's Avatar
ok i was not geting fuel 2 the rail(bad main reley) fixed that. now i put the d series injectors back in car start up fine. just worried about messing something up agian, trying 2 get dsm 450s now
solsquad27
May 15, 2012 11:54 PM
one slooow dc4
Nov 29, 2009 08:33 PM
turbo_ef9
Jan 24, 2005 09:47 AM
project142
Jan 27, 2004 08:53 PM
LuderSH
May 2, 2002 08:49 PM
