Fuel Pressure Settings...
Old Aug 6, 2002 | 07:09 AM
PrecisionH23a's Avatar
Default Fuel Pressure Settings...
I did a search and didnt quite find the answers i was looking for. A rough breakdown of my set up is the following:
t04e ball bearing
fully rebuilt block+internals
full head work
-8an feed, -6an return steel braided lines
walbro 255 intank fuel pump
paxton fuel filter
paxton fuel pressure regulator
rc 720cc injectors
AEM fuel rail
My question is, at idle what should i set my fuel pressure to be? I saw on some threads they recommend 40-47with hose on and like 37-41 with hose on, but i just wanted to ask you guys just to be on the safe side. Also, this will be the settings i need BEFORE i put my hondata 4b on, will i need to change the pressure once i have the 4b installed? I am going to have it dyno tuned 3 weeks after i get the 4b on, i just need it in good driving condition until i do so. Thanks guys
[Modified by GudeH23a, 11:16 AM 8/6/2002]
Old Aug 6, 2002 | 10:20 AM
Sonny's Avatar
Default Re: Fuel Pressure Settings... (GudeH23a)
How do you plan to even use those injectors before you get the Hondata installed? They are like 2.5 times larger than stock. I don't think your ECU will be too happy without some kind of fuel controller.
Sonny
Old Aug 6, 2002 | 10:25 AM
93LSivic's Avatar
Default Re: Fuel Pressure Settings... (Sonny)
Yeah, you wont be able to idle those things w/o the hondata.
To answer the question, considering the hondata is installed. You would want 50 psi atmospheric. Ofcourse you will have to tell the hondata this when you burn the chip.
Old Aug 6, 2002 | 10:38 AM
Default Re: Fuel Pressure Settings... (93LSivic)
i forgot to mention that im running the stock 240cc injectors untill i have the hondata installed....
boostedgsr1234
Jul 14, 2007 05:52 PM
Shmaa
Jul 7, 2006 04:59 PM
jsimon9633
Mar 11, 2005 11:30 AM
Z6REX-SI
Jan 13, 2004 11:13 AM
ZERO COOL
Jul 28, 2002 12:22 PM
