Fuel pressure problems....
Old Jun 12, 2009 | 05:16 PM
integaman's Avatar
Default Fuel pressure problems....
A little background info... stuff i think you will need to know to help me out. If you need any other info just let me know. I appreciate ANY help anyone can offer me.
'97 GSR Integra... Sleeved GSR motor, 60 trim turbo, cast manifold, AEM (universal FPR), all stock fuel lines, B&M fuel pressure guage on top of filter, and 255 Walbro fuel pump.
I installed the FPR directly to the OEM fuel rail using an adaptor fitting. I was actually quite pleased on how it is set up. Considering i didnt have to put it on the firewall and run uneccesary fuel lines. I contected the feed line and vacuum line up to it and im having some problems.
After i checked for leaks several times, i started the car up and proceeded to adjust the fuel pressure. My current fuel pressure is right at 80 psi. I am trying to get it down to 45 psi which to my understanding is stock. I turned the adjusting allen bolt counter clockwise all the way out and the pressure is not changing. Maybe 2 to 3 psi, but nothing really worth anything. Also i need the FPR to working properly for the tuner to be able to adjust it. Which is in 6 DAYS
Before i installed the AEM fpr i installed a BLOX fpr. i know the pieced isnt the best quality unit but i had the same problem.
Another thing that might help yall is that the guage on the FPR ( AEM and BLOX ) is reading Zero PSI. but the guage on the filter is reading 80psi.
Again anthing will be appreciated. Thanks a lot
-Joe
superhatchbackbros
Oct 7, 2006 10:51 PM
6_GeArEd_TEG
Nov 27, 2004 09:57 PM
alpha_1
Nov 22, 2004 06:13 AM
hybrid_vtec
Aug 5, 2004 10:03 AM
boostaholic
Jun 30, 2002 07:25 PM
