Fuel pressure on a nitrous setup
Just curious what you're Fuel Pres. is at idle w/ your nitrous setups.... I have mine at 40 and wasn't sure if it's to much.....
OR YOU CAN RUN a fule pressure regulator on the fuel side of the nitrous kit and use it to tune your setup. need more fuel up the pressure a bit, ned less drop it down. start out with it set the same as your engines fuel pressure and work from there. Save time instead of rejetting and you dont have to buy as many pills. Pills get expensive if your tuning a DP setup.
my setup is a dry kit... It's just that I noticed it start to lean out on the track... the only pres. reg. I have is the one on the fuel rail... B&M
baphomet
Jul 19, 2003 09:01 AM
92SiB18C1
Apr 25, 2003 05:35 AM
