Fuel pressure in acc2?
Old Mar 29, 2004 | 12:33 PM
monicle's Avatar
Default Fuel pressure in acc2?
When I turn my car to accessory 2 position and the fuel pump primes. should I have a constant pressure or is it suppoesd to drop off if you dont start the car?
Old Mar 29, 2004 | 12:44 PM
TeamCracka's Avatar
Default Re: Fuel pressure in acc2? (monicle)
After I shut my car off it goes down to zero in a few seconds. I never had the problem before I installed a Walbro 255
Old Mar 29, 2004 | 12:47 PM
monicle's Avatar
Default Re: Fuel pressure in acc2? (TeamCracka)
right but what about if I still have it in acc2? should I still have a constant pressure?
Old Mar 29, 2004 | 01:10 PM
porsche997dc2's Avatar
If you have a stock fpr it should hold for awhile. If you have a aftermarket one (aeromotive or paxton), the fp drop to zero once the ignition is off or on AccII.
Old Mar 29, 2004 | 01:22 PM
monicle's Avatar
Default Re: Fuel pressure in acc2? (porsche997)
k yeah im using an aeromotive FPR and I dont have the car running yet but when I was pressurizing the system to check for fuel leaks I would see it go up hold for several seconds and then start dropping. Just wanted to make sure everything was cool.
Old Mar 29, 2004 | 01:29 PM
Don't worry about. The oem are designed the hold fp for awhile once you turn off the ignition. It's for emission purposes. I did talk to the tech from aeromotive, they said it a normal for their fpr to drop to zero once the pump is not running.
jman86
Nov 7, 2024 12:19 PM
boosted 95 coupe
Sep 12, 2008 04:43 AM
KRWTEK1
May 28, 2007 02:53 PM
Boognish
Jul 24, 2005 08:16 PM
