fuel is not enough
Old Sep 12, 2010 | 03:36 AM
PTVDesign's Avatar
Default fuel is not enough
HONDA ACCORD CD3 EX
engine: F22B DOHC (Prelude BB5)
ecu: P28 Phearable chip
injectors: obd2 240cc
fuel pump: ACCORD / torneo f18b
if i set on fuel pressure regulator 5.5 kg/cm2 then car is go nice, if i set 3.2 kg/cm2 or install oem fuel pressure regulator then car is slow accelerate
fuel pump? valve clearance? ignition? timing marks? please help
Old Sep 12, 2010 | 10:08 AM
jesus_ralliart's Avatar
Default Re: fuel is not enough
not sure what the OP is getting at but sounds like a tuning problem?
Old Sep 12, 2010 | 11:12 AM
2k.civic.si's Avatar
kg/cm2: 5.5 converts to
psi: 78.1000
kg/cm2: 3.2 converts to
psi: 45.4400
Something is wrong if you need that much fuel pressure to run correctly. You should be setting the fuel pressure regulator at 3.2 kg/cm2 with the vacuum hose off
ecu: P28 Phearable chip <--- this could be your problem.
Old Sep 12, 2010 | 05:13 PM
PTVDesign's Avatar
psi: 78.1000
psi: 45.4400
yes i set when vacuum off
if 3.2 kg/cm2 then bad, if 5.5 then fine.
78 psi on 240cc it's 320cc
maybe need chamge injectors?
Old Sep 13, 2010 | 07:55 AM
dpetro1's Avatar
is the car turbocharged? sounds like a tuning issue with the chipped ecu. what happens if you reinstall the stock ecu and set to factory base pressure?
Old Sep 13, 2010 | 03:59 PM
PTVDesign's Avatar
isn't charged.
on stock ecu idle is not stable, i try all. no leak. when i add fuel pressure - idle is normal, and car run fine.
when i change ecu on chipped p28 and set the base pressure - idle is bad and car run bad. when i add the pressure car run fine.
Old Sep 16, 2010 | 04:54 AM
PTVDesign's Avatar
help
jman86
Nov 7, 2024 12:19 PM
yywjsutherla
Honda CR-V & Element
Sep 13, 2017 12:38 PM
ojasia
Oct 30, 2014 07:22 AM
jaredvabeach
Aug 6, 2008 07:38 PM
Daniel-sanB1
May 28, 2006 10:31 PM
