Fuel management
Old Mar 25, 2003 | 06:46 PM
Cee_mon's Avatar
Default Fuel management
Hey guys...i need alittle help here...I just bought a used greddy kit with intercooler for my d16z6(95 coupe). For fuel management it came with the black box, 8:1 FPR, and manuel boost controller. Are there any other things i need to run 7 psi with the intercooler. The rest of the engine is stock.
Also do i need different spark plugs and wires?
[Modified by Cee_mon, 9:57 PM 3/25/2003]
Old Mar 26, 2003 | 04:12 AM
Cee_mon's Avatar
Default Re: Fuel management (Cee_mon)
no one can help me out???
Old Mar 26, 2003 | 04:24 AM
Charlie Moua's Avatar
Please use search next time!
you should be good to go.
get some new plugs if your worried. stock wires are fine.
Old Mar 26, 2003 | 04:25 AM
ekb18c's Avatar
You should be fine with that setup. Run colder plugs and you will be okay.
Cee_mon's Avatar
Default Re: Fuel management (Charlie Moua)
i did search...but there arent alot of people here running the same setup....stock internals with turbo and intercooler.
Should i get colder plugs? Or how do i tell which ones?
Old Mar 26, 2003 | 05:03 AM
Pengo's Avatar
i heard some info way about the black box not being that great. i dont have personal experience b/c i'm running the newer blue box. with the blue box you dont need the fpr. my fuel setup for 7 psi right now is basically blue box, rc 310s, walbro 255, aem fpr, and ngk plugs 1 step colder (6 range). you may want to run 1 degree retarded ignition to be on the safe side. the rest of the setup is greddy kit, stock internals, 1g dsm bov, 1g dsm smic, hallman mbc
[Modified by Pengo, 9:04 AM 3/26/2003]
Bimmerman
May 6, 2005 04:30 PM
VinceVTEC
May 21, 2004 09:20 PM
dmah
Oct 11, 2003 02:01 PM
turboD16
Oct 8, 2003 10:46 AM
Maverick77
Nov 12, 2002 02:13 PM
