Fuel line sizes.
I'm currently running a Weldon DB2025-A fuel pump which uses a -12an feed and a -10an out. Problem is, my fuel tanks sump has two -10an holes for feed instead of the -12an. I'm wondering if it should be fine to run just a single -10an to the pump or if I should take both -10ans off the fuel tank and Y them into a -12an to make sure I'm getting all the fuel to my pump that it needs.
I just don't want to starve the thing and possibly see a pressure drop while I'm racing, and unless you guys think the single -10an will be fine, I'll go with the duals Yed into a single -12an.
Also, yes this is a 1400hp fuel pump and my goal is 1100whp.
ROGUE STATUS
Sep 1, 2012 05:57 PM
Tyson
14
Mar 29, 2004 12:05 AM
