which fuel injectors?
Old Oct 16, 2003 | 09:38 AM
inspecta83's Avatar
Default which fuel injectors?
ok, here's my setup.... '91 b18b crx, hondata2b, wolbro 255lph fuel pump, and i'll be boosting 10psi (and i kept the crx wiring so its still obd 0 with the resistor box)... i spoke to the peeps at rc engineering and they said that with my set up i would need 370cc peak and hold injectors. does that sound correct as far as size and spec (i.e. peak and hold instead of saturated)?
also, since i dont have the $300+ to spend on their injectors i wanted to use the injectors from an eclipse since i heard of other people doing this b4 and its cheaper. please let me know what yr/model eclipse injectors i would have to get. i know that since i am using the crx wiring with the resistor box, i would need obd 0 peak and hold injectors. thanks!
JDM-JAMES
Feb 18, 2009 06:57 PM
sevenj
May 21, 2008 04:50 PM
VaporTrail
Feb 11, 2002 09:23 PM
BoostedSi
Jan 25, 2002 04:33 AM
