Fuel guage help
I tapped the end of a b16 fuel rail to 1/4 npt. The b16 ones are billet and have a brass plug at the regulator end, so I just drilled it out. I also have a b18 fuel rail but it was cast and there is no where easy to drill.
Summit makes a fitting that splices into your fuel line and accepts a liquid-filled gauge:
SUM-G1710
Click to view image
$5.99
Overview
Material Aluminum
Finish Polished
Diameter 3/8 in.
An easy way to install a fuel pressure gauge
Universal, aluminum, polished finish, 3/8 in. diameter barbed ends, fuel pressure gauge fitting
This aluminum fitting has a 1/8 in. NPT port to install one of our fuel pressure gauges or other accessories in your fuel line--wherever you want to put it. For use with 3/8 in. hose.
Sold individually.
Would that accept a sending unit for an electrical gauge?
SUM-G1710
Click to view image
$5.99
Overview
Material Aluminum
Finish Polished
Diameter 3/8 in.
Sold individually.
