crower help
Old Aug 3, 2002 | 11:48 AM
W.Zero's Avatar
Default crower help
does it matter which way you connect the rods? on one side of the rods it reads H1-H4 and i was told that those are surpose to face the back of the block, is this true?
Old Aug 3, 2002 | 11:53 AM
*Boostwerks*'s Avatar
Default Re: crower help (W.ZeroB18C1T)
I have a question to add....(sorry)
I have crower's as well, and I can't seem to remove the lower cap from the rod.
They have been used, but they had to remove the cap to get the rod off anyway...so how do I remove it without damaging the bearing surface?
Thanks
Old Aug 3, 2002 | 11:59 AM
W.Zero's Avatar
Default Re: crower help (Bryson)
Thanks
put the screws barely on hold the cap and lightly tap the screws and it should seperate.
Old Aug 3, 2002 | 12:00 PM
PrecisionH23a's Avatar
a rubber mallet also works, just lightly tap them and they should come loose. im trying to find a pic to answer your question as to how to mount the rods, when i find the pic ill post it up
Old Aug 3, 2002 | 12:07 PM
Default Re: crower help (GudeH23a)
ok, the stampings on the caps of the rods dont matter if they face the intake or exhaust side as long as all 4 of them are UNIFORM with each other. that means, markings facing all in 1 direction and not opposite to one another.
Old Aug 3, 2002 | 12:12 PM
W.Zero's Avatar
thanks that helps alot!
Old Aug 3, 2002 | 12:24 PM
Thanks as well!
R.sok
Suspension & Brakes
Dec 20, 2011 09:37 PM
msinsky14
Apr 23, 2007 05:00 PM
Stefndogg
19
Dec 14, 2004 05:41 PM
RedRacerCivic
Dec 24, 2003 03:36 PM
