Friggin WG dump routing interfering with hot side (pic(
Old Jun 10, 2007 | 09:18 PM
Ls1 FD3s's Avatar
Default Friggin WG dump routing interfering with hot side (pic(
The flange i have for the dump is friggin thick like 14mm, so that allows for just a little more than one finger's width between the flange and hot side. I could flip the WG, then run some goofy *** 180* dump back down, but not stoked about that. Also, i could cut the flange off the mani and clock it, but i would rather not have to customize an expensive mani.
Anyone else run into this problem? How did you deal with it? Pics!
Old Jun 10, 2007 | 09:39 PM
Turbogixxer's Avatar
Default Re: Friggin WG dump routing interfering with hot side (pic( (Ls1 FD3s)
Can you flip the turbo?
What manfold is that?
Old Jun 10, 2007 | 09:40 PM
sohc_turd's Avatar
i think you've already named all 3 possible options.
Who made the manifold anyway?
Old Jun 10, 2007 | 10:08 PM
Ls1 FD3s's Avatar
Default Re: Friggin WG dump routing interfering with hot side (sohc_turd)
Slomotion industries same guys that make shearer (sp?) manis for DSM's so i was told from the seller. Its a quality piece for certain minus this WG dump BS.
I cannot flip the turbo, the cold side's diameter is larger than that of the hot sides therefor causing even more interferance problems. Not to mention i dont want any piping with exhaust gasses remotly near my compressor...
Old Jun 10, 2007 | 10:21 PM
sohc_turd's Avatar
Default Re: Friggin WG dump routing interfering with hot side (Ls1 FD3s)
I think the best fix would be to take it to a competent welder and have the flange chopped off, repositioned, and welded up. It shouldn't cost much.
Old Jun 10, 2007 | 10:23 PM
null.'s Avatar
yeah just cut and re weld the flange.
OR
buy the 38mm to 44mm flange and run a 44mm wastegate
Old Jun 10, 2007 | 11:59 PM
bigbadboy's Avatar
they make adapter flanges so you can rotate the WG. go to ATPturbo.com and look
Old Jun 11, 2007 | 03:14 AM
DaveF's Avatar
Default Re: (bigbadboy)
i had the same problem, just that the guy that welded this one placed the gate facing down over top the center cartridge. we cut the flange off and rotated it a few degrees.
this is the end result, sorry for the pic, its not the best lol
Old Jun 11, 2007 | 07:42 AM
esedulerp5tenin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbadboy &raquo;</TD></TR><TR><TD CLASS="quote">they make adapter flanges so you can rotate the WG. go to ATPturbo.com and look</TD></TR></TABLE>
http://www.atpturbo.com/Mercha...e=WGT
thats absolutely awesome!!!
looks like its either that, or cut the flange and rotate/weld it @ 90 degrees
Old Jun 11, 2007 | 08:24 AM
JDogg's Avatar
Default Re: (esedulerp5tenin)
turn the turbo around... problem solved, the turbine wont be anywhere near the wg dump
Old Jun 11, 2007 | 08:31 AM
turbodohcsi's Avatar
yeah, i think its just a matter of turning the turbo around. that way the housing curls back up under the manifold and not out under the wastegate.
Old Jun 11, 2007 | 09:09 AM
ExVtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls1 FD3s &raquo;</TD></TR><TR><TD CLASS="quote">Slomotion industries same guys that make shearer (sp?) manis for DSM's so i was told from the seller. Its a quality piece for certain minus this WG dump BS.
I cannot flip the turbo, the cold side's diameter is larger than that of the hot sides therefor causing even more interferance problems. Not to mention i dont want any piping with exhaust gasses remotly near my compressor... </TD></TR></TABLE>
Ryan is on here (teglove2)...he is the one that probaly made it..I am sure he will chime in when he sees this..
Modified by ExVtec at 1:57 PM 6/11/2007
Old Jun 11, 2007 | 09:17 AM
g2turbo's Avatar
Default Re: (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">i had the same problem, just that the guy that welded this one placed the gate facing down over top the center cartridge. we cut the flange off and rotated it a few degrees.
Thats one of Lovefabs old mani's isnt it?
Old Jun 11, 2007 | 12:05 PM
A.E Motoring's Avatar
just turn it upside down and route the dump tube,simple
Old Jun 11, 2007 | 12:25 PM
banmeagain's Avatar
Default Re: Friggin WG dump routing interfering with hot side (Dual Cam Racing)
Flip the WG, shoot the dump tube out the hood. Will look bad *** and work just fine. Thats how I'm doing mine
Old Jun 11, 2007 | 03:20 PM
DaveF's Avatar
Default Re: (g2turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2turbo &raquo;</TD></TR><TR><TD CLASS="quote">
Thats one of Lovefabs old mani's isnt it?</TD></TR></TABLE>
HT user, 'Composimo'(John) made the manifold, when his company was RPI Racing, i believe its now called Icon Auto.
Old Jun 11, 2007 | 07:37 PM
Ls1 FD3s's Avatar
Default Re: Friggin WG dump routing interfering with hot side (banmeagain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by banmeagain &raquo;</TD></TR><TR><TD CLASS="quote">Flip the WG, shoot the dump tube out the hood. Will look bad *** and work just fine. Thats how I'm doing mine </TD></TR></TABLE>
X2! haha j/p
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbodohcsi &raquo;</TD></TR><TR><TD CLASS="quote">yeah, i think its just a matter of turning the turbo around. that way the housing curls back up under the manifold and not out under the wastegate.</TD></TR></TABLE>
I dont wanna flip the turbo, that changes all my IC piping, DP, air filter plumbing, and puts the compressor in a more hotter enviroment. Gotta respect the enviroment!
I may go with the flange that clocks the WG, simple, easy, effective, non permanant. Plus i dont have an upper radiator core support on my car. PLENTY of room!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExVtec &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by ExVtec at 1:57 PM 6/11/2007</TD></TR></TABLE>
he is the man i purchased the mani from, i forgot his username, hence why i hadnt contacted him.
Old Jun 11, 2007 | 08:10 PM
paulzy's Avatar
WHy not just flip the WG so the outlet faces up and run a 180 bend back down to where ever you're gonna route your downpipe?
Old Jun 11, 2007 | 09:26 PM
Ls1 FD3s's Avatar
Default Re: (paulzy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paulzy &raquo;</TD></TR><TR><TD CLASS="quote">WHy not just flip the WG so the outlet faces up and run a 180 bend back down to where ever you're gonna route your downpipe?</TD></TR></TABLE>
Its like having a 13" *****, but its as skinny as a pencil, it just aint right, haha.
Old Jun 11, 2007 | 11:18 PM
KeyserSoze's Avatar
Default Re: (Ls1 FD3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls1 FD3s &raquo;</TD></TR><TR><TD CLASS="quote">Its like having a 13" *****, but its as skinny as a pencil, it just aint right, haha.</TD></TR></TABLE>
Nah, here's how I did it.
https://honda-tech.com/zero...ge=65
Old Jun 12, 2007 | 06:40 PM
Ls1 FD3s's Avatar
Default Re: (KeyserSoze)
very nice. Straight up out the hood would be ****** hilarious tho!
that $28 90* clock flange is the cats *** IMO. Got it on order...
95civhb
Feb 27, 2010 11:40 AM
CA6VTEC
Feb 24, 2006 07:24 PM
640K Crew
Feb 24, 2006 05:46 PM
Luserkid
Welding / Fabrication
Sep 20, 2005 09:06 PM
RACEPAK
Feb 22, 2005 03:01 PM
