friction material of oem ITR flywheel in combo with Tilton carbon clutch
Will I get the same clamping power when I use my stock flywheel with the Tilton twin disc carbon clutch like with the Tilton flywheel. I don't wanna run this azz-light Tilton fly.
Thanks
Thanks
Re: friction material of oem ITR flywheel in combo with Tilton carbon clutch (austrian type-R)
What does it do to your setup that makes you not like it? Does your engine stall? Why don't you like it?
Re: friction material of oem ITR flywheel in combo with Tilton carbon clutch (Dr Pooface)
I had a fidanza and I did not like it, this one is way lighter than the fidanza and the clutch itself is 10 times lighter than a oem clutch
Smarter than you
Why do you need the carbon/carbon tilton? I think you would be more then OK w/ the ceramatalic tilton. Its good for 500ft'lbs of torque. Its what most honda guys run on the street/strip cars. I know of a 520whp civic running the ceramatilic w/ stock flywheel that has been lightened to about 12lbs(perfect IMO) and he does not have any problems at all w/ clamping so id say you'll be ok.
Re: friction material of oem ITR flywheel in combo with Tilton carbon clutch (DIRep972)
I have the clutch at home already and this is not my question, cause this light Titlon fly is included for the cintermetall too. Carbon / carbon is way smoother for the tranny, etc.
SLEEPER775
08-24-2008 10:21 AM
ahemming06
06-06-2006 07:52 AM
VaporTrail
01-23-2004 04:22 PM
