Freezer PLug Blowout
Old Apr 10, 2005 | 05:46 AM
NVturbo's Avatar
O.G. triple O.G.
Default Freezer PLug Blowout
As I was racing this silver EVO last night, my damn (34.3mm) freezer plug blew out and oil sprayed all over. The bad thing about it was I used some black silicone sealant instead of HondaBond to seal it off, but how come it finally blew out after all this time. By the way, I was @ full boost (14.5psi) and in 5th gear. I'm just crossing my fingers I didn't mess anything else up because the motor sounds like **** now with that hole is exposed (where the OEM black catch can used to be). Has this ever happened to anyone else?
Old Apr 10, 2005 | 07:55 AM
earl's Avatar
Default Re: Freezer PLug Blowout (NVturbo)
So you put a freeze (not freezer) plug where your breather used to be? How were you venting the pressure in the pan?
I suppose if you blew a piston and pressurized the pan, something would have to give.
Old Apr 10, 2005 | 10:37 AM
civicross's Avatar
Default Re: Freezer PLug Blowout (earl)
Core plug
Old Apr 10, 2005 | 08:53 PM
NVturbo's Avatar
O.G. triple O.G.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">So you put a freeze (not freezer) plug where your breather used to be? How were you venting the pressure in the pan?
I suppose if you blew a piston and pressurized the pan, something would have to give.</TD></TR></TABLE>I did mention it was a "freezer" plug. And no it is not where the breather used to be...it is where the stock "black catch can" used to be on the back of the block (PCV valves). I used two OEM Honda barb fittings (where the stock plugs were) and ran them to a catch can....with a fitting/tubing on top of the catch can to the charger pipe for vacuum.
fbp-em1
Honda S2000
Mar 11, 2008 06:22 AM
blakacintegra
May 12, 2007 08:52 PM
motormike40
Apr 7, 2007 03:02 PM
navin
Sep 16, 2004 04:22 PM
crxgator
29
Jul 17, 2004 05:48 AM
