Forged piston shopping..
Old Dec 31, 2010 | 02:19 PM
LS/V-T's Avatar
Icon2 Forged piston shopping..
Hey guys I need your help with looking for a good set of forged pistons..
I have a b18a1 block that has 84.5mm darton mid sleeves installed. I will be using a set of eagle h beam rods, a lightened ls crank and a GSR head.
My goal is to make 500whp on pump gas.. If you need anymore info just ask..
Old Dec 31, 2010 | 02:39 PM
sanman000719's Avatar
Default Re: Forged piston shopping..
cp/eagle good combonation
Old Dec 31, 2010 | 02:43 PM
92redhatch's Avatar
I run je/eagle
Old Dec 31, 2010 | 03:06 PM
LS/V-T's Avatar
I currently have a set of je pistons.. I am rebuilding due to a spun rod bearing. During the rebuild I noticed that piston # 2 and 3 ring grooves are too tight for the new rings. Seems like the pistons swelled or something..
Is this a common problem with forced induction engines ?
Old Dec 31, 2010 | 03:14 PM
t66crx's Avatar
wiseco pistons are good
Old Jan 1, 2011 | 06:01 AM
LS/V-T's Avatar
I've been looking at these.. Wiseco Acura/Honda forged piston set - K649M845.
Let me know what you guys think about these pistons.. Who has the best pricing for Wiseco pistons?
Old Jan 1, 2011 | 06:53 AM
IN VTEC's Avatar
A change in the piston diameter wouldn't affect ring gap. Ring gap is dependent on the circumference of the piston ring and cylinder bore diameter.
Ring tension is also a variable, but you should consider it a constant when determing ring end gap clearance by assuming it has the minimum tension to maintain contact around the entire diameter of the cylinder bore.
I would consider the alignment of the ring being out of square between the first and last measurement or a difference in the feeler gauges you used.
Old Jan 1, 2011 | 07:56 AM
LS/V-T's Avatar
The problem I have with my current pistons isnt due to the piston overall size being too large now..
When we installed the rings they are too tight top to bottom. It's like the rings are too thick to fit in the pistons. We measured every thing correctly too.
Old Jan 1, 2011 | 11:33 AM
IN VTEC's Avatar
Is it the rings or the piston? Mic the rings and feeler gauge the ring seats on the pistons.
Old Jan 1, 2011 | 02:41 PM
LS/V-T's Avatar
The rings are perfect.. There was quiet a bit of ware on the piston skirts too.
Old Jan 1, 2011 | 02:53 PM
darkvader0's Avatar
I've been running Endyn/Wiseco 84.5mm pistons in my setup for 8 years and ~70K miles now. Still runs like a top.
Old Jan 2, 2011 | 06:39 AM
LS/V-T's Avatar
Do you have a link to veiw endyn pistons? A local shop was just telling me to take a look at endyn gas port pistons..
Old Jan 2, 2011 | 09:41 AM
darkvader0's Avatar
Yeah you can see the application chart here:
http://www.theoldone.com/components/pistons/
Old Jan 5, 2011 | 09:19 AM
LS/V-T's Avatar
Is it common to show signs of detonation on the intake side of the piston near the ring lands??
Any body have pics of light detonation on pistons from a honda engine?
Dc4LsTeG
Jul 6, 2012 11:16 PM
Youlose1305
May 4, 2006 10:39 PM
hondadxsi
Nov 9, 2005 10:36 PM
