for the Forced Induction folks....
Old Feb 10, 2010 | 09:12 PM
madking411's Avatar
Default for the Forced Induction folks....
just a question; i know they say that there are a few ways that a boosted vtec motor can be destroyed, IE; boost creep, running lean, overboosting, all of which result in cracking sleeves/pistons, etc., but what i was wondering is, isnt there a way to prevent any of that stuff? Like through the computer, if you're running an OBD1 setup?
I've heard of some way that Subarus keep that type of stuff under control, like it does some kindof ignition cut, or "safe mode" if the computer can sense the engine starting to overboost? Is there something like that for those of us who use Crome for tuning, or is that a feature that exists in Hondata only?
(or does it not exist at all......?)
I'm only asking because, well i haven't gone FI yet, but when that day comes, i just wanna know how to prevent destruction before it even has a chance to happen.
Old Feb 11, 2010 | 04:25 AM
zx10dencies's Avatar
Default Re: for the Forced Induction folks....
It's not preventable, if it were then no one would blow up their multi-thousand dollar motor setups, no one ever decides to go "ehh I'll just blow it up today, I'd like something else to do."
that said, things like a good tune, good fuel, proper parts, and strangely common sense can keep the chaos organized and manageable. There are safety checks in place with Hondata, while I can't speak for chrome, Neptune etc I'd surely hope they have them as well. Overboost protection, cold warm up boost protection, etc. However none of the computer setups are going to have idiot driver protection. They simply do the best they can with as much technology as possible to keep us from F'ing up the whole setup.
Old Feb 11, 2010 | 05:32 AM
zedron's Avatar
I know eCtune has a fail safe for overboosting that cuts the ignition. I am pretty sure Crome has the same thing.
Old Feb 11, 2010 | 08:15 AM
Schister66's Avatar
Man U FTW
Moved to Forced Induction...
Old Feb 11, 2010 | 08:20 AM
TheShodan's Avatar
Moderator
Subarus, DSMs, Evolutions, Mazads, Mustanges ALL face the same challanges as any other turbocharged (or NA for that matter) vehicle. Even with these safety features that you've stated, it can still go wrong if not tuned well from the beginning.
Old Feb 11, 2010 | 08:21 AM
raene's Avatar
Pretty much every ROM editor since Uberdata has had overboost protection.
Old Feb 11, 2010 | 10:40 AM
avotegra's Avatar
sorry to thread jack, but this topic run with this thread. Is there a lean fuel cut off or motor shut down using a wideband....like if the ecu start to seeing a lean mixer then it shut the motor down....that would be nice.....
Old Feb 11, 2010 | 10:48 AM
boostedEF91's Avatar
Wideband readings are always going lean and rich. it would be impossible unless it would work with a WOT pull. then it would be ok.
Old Feb 11, 2010 | 11:17 AM
BuiltDC2's Avatar
Good tunes save a lot of money. Spend the money tuning and youll be OK for a while.....
Old Feb 11, 2010 | 11:47 AM
Seraph0's Avatar
Hondata has this exact feature. I am unsure if the others do.
Old Feb 11, 2010 | 11:48 AM
Seraph0's Avatar
Yeah the ECU knows when you are WOT so I can just have a statement in the code like:
IF TPS > 80% AND MAP > xxx mbar AND lambda > 0.90 THEN cust ign./fuel.
something along those lines.
95civhb
Engine Management and Tuning
Apr 30, 2009 07:37 PM
Silverhatch
Aug 3, 2004 12:02 PM
7rrivera7
Aug 1, 2003 12:27 PM
GOLDBERG
Apr 29, 2003 09:03 AM
