Force Induction on B16A
Old Sep 3, 2002 | 03:56 PM
EF8_SiR's Avatar
Default Force Induction on B16A
Are there any kits out there that makes FI for the gen1 B16's? Inquiring into the Greddy B16 kit there is actually some modification needed with the ECU, etc b4 this kit will work.
Also for all ppl with F.I. what compression are u running at? Wouldn't lowering compression disprove the whole pt of havin the b16 in the first place though?
Old Sep 3, 2002 | 04:19 PM
keebler65's Avatar
Default Re: Force Induction on B16A (EF8_SiR)
i cant answer the first part but yes, lower compression is better from what i hear if you're going FI. or maybe i should say more reliable?
Old Sep 3, 2002 | 04:59 PM
Griffins_Importuning's Avatar
Default Re: Force Induction on B16A (keebler65)
yes...the fmax kit is a great kit for our swaps...it fits the crx w. b16...comes w. everything needed. also comes with new injectors and a thick *** head gasket ...that lowers the comression to 9:? you can safely run 10 psi on a stock engine with this kit..as much as 12....but if u go w. drag kit no more than 8......i talked to a performance specialist about it the other day...
Old Sep 3, 2002 | 07:30 PM
.ShawnD.'s Avatar
Default Re: Force Induction on B16A (Griffins_Importuning)
revhard makes a kit for it .. i thought about it awhile back.. nice kits good price
you should only lower your CR if your planing on running 8+ psi other wise keep it stock with a nice head gasket and better then stock clutch youll love it with just 5 trust me!!
Old Sep 3, 2002 | 07:45 PM
slywfbpsi's Avatar
Default Re: Force Induction on B16A (.:s h a w n D:.)
do all of these kits let you keep a/c with the b16 swap?
Old Sep 3, 2002 | 08:10 PM
Phatwhippin_CRX's Avatar
Default Re: Force Induction on B16A (slywfbpsi)
RevHard makes the best B series Turbo kit, hands down..... if you've got the cash...
And no, chances are you'll have no room for A/C with the turbo mounted in there..... hell, sometimes you are better off with a 5g Civic Radiator to actually get some room up front....
Old Sep 4, 2002 | 06:07 AM
EF8_SiR's Avatar
Default Re: Force Induction on B16A (Phatwhippin_CRX)
How much would one be looking at for the RevHard kit?
So what ur saying also is that it's recommended to through in an eg6 rad into the car instead?
Old Sep 4, 2002 | 06:52 AM
FOrSfEd's Avatar
You can actually run up to 22psi on stock internals with 1 b16 with good fuel management, such as hondata or Zdyne, the fmax kit is good cause I have it, but the Mf2 controller and two extra injerctors suck honestly, get a hondata or Zydne and fine tune it and you can run 13+ psi driven daily, and be hella fast.
Lee
Old Sep 7, 2002 | 10:47 AM
LethalX's Avatar
New User
dood.. wtf? I told u... GO TURBO GO TURBO and your like no. im staying NA and this was like 2 days ago? haha you said turbo is too costly and unreliable for u! haha i disagree!! and now your asking peeps about turbo kits etc? lolz...werd
Old Sep 7, 2002 | 11:32 AM
HybridKOOP's Avatar
Default Re: Force Induction on B16A (Rex2nv)
You can run 50psi of boost on a 1st Gen B16A as well... but just like with your 22psi setting... do you see it lasting? Maybe for a gear or two.
Old Sep 7, 2002 | 03:55 PM
Ltech's Avatar
Lee
22psi on stock components? What make you say that?
Old Sep 7, 2002 | 04:56 PM
slywfbpsi's Avatar
Default Re: Force Induction on B16A (Ltech)
If he's talking about 22psi on stock internals on race gas, the guys at inlinepro have been doing it for years with just changing out the head gasket. Even st00pid's low budget civic with an ls engine is doing 29psi on pump gas and stock internals.
dev203d
Jan 17, 2011 04:45 PM
civictildeath
10
Jan 16, 2006 09:13 PM
s2kkid
Dec 26, 2004 06:52 PM
B18cyelowciv
Nov 15, 2002 06:13 PM
Trevor
Oct 7, 2002 05:31 AM
