FMU ratio?
Old Mar 14, 2003 | 06:32 PM
1.8Tities's Avatar
Default FMU ratio?
What FMU ratio for a d16a6 turbo? Input will be greatly appreciated...
Old Mar 14, 2003 | 06:41 PM
bottlefedb18c1's Avatar
Default Re: FMU ratio? (4thGSi)
it depends on what injectors you have in it?
Old Mar 14, 2003 | 06:45 PM
B18Flip's Avatar
Default Re: FMU ratio? (boostfedb18)
will stock injectors work?
Old Mar 14, 2003 | 06:51 PM
Default Re: FMU ratio? (B18Flip)
the stock injectors will but you need a 12:1 fmu if you use the stock injector FOR THAT MOTOR not say a DSM
Old Mar 14, 2003 | 06:54 PM
1.8Tities's Avatar
yeah stock injectors guys...
Old Mar 14, 2003 | 08:04 PM
B18Flip's Avatar
Ok cool..4thGsi and I will be putting together his turbo setup. Here's what we think we need....
turbo manifold, 14b DSM turbo, DP, 12:1 FMU, IC and piping, bov, oil return/feed, air filter and maybe a highflow fuel pump ( is this needed?)
Anything else?
Old Mar 14, 2003 | 08:33 PM
evoeone's Avatar
Anything else?
why would yo run a vortech fmu i am assuming? you have to deal with those calibration disks... get an adjustable cartech.... and use a t series turbo man, what are you dsm
Old Mar 15, 2003 | 12:21 AM
Tomek's Avatar
Default Re: FMU ratio? (evoeone)
RJ, run the AFC hack or the SMC w/450's it'll run a lot smoother. The 12:1 fmu with stock injectors would be sufficient but it may not feel like a factory turbo car at times if you know what I mean. Ask Ivan he ran an FMU before, there's a reason he switched to the hack. Plus if you spend a little more with the afc hack or smc you'll always have that potential to run up to 10psi if you feel confident enough to. That added adjustability is worth it. Look into it before you make a choice, proper fuel management is vital to getting the car to run like you want it to, safely. Highflow fuel pump isnt really necessary, I'm not runnning one neither is Ivan. If you run the std manifold I give you you'll need an adapter plate, you'll also need a boost gauge as well so add that onto your list, an egt gauge would be a good idea too. If you decide to run dsm 450s make sure you run dsm or GM injector clips since you have the y8 fuel rail, you wont need the resistor box since your car has one stock. Otherwise thats about everything, just make sure you research every option so once you know what to get itll be exactly what you want.
Can't wait to see you join the darkside with me
link for smc
http://userwww.sfsu.edu/~ecg/smc.htm
afc hack thread
https://honda-tech.com/zerothread?id=137901
[Modified by AztecEJ, 3:36 AM 3/15/2003]
Old Mar 15, 2003 | 03:51 AM
1.8Tities's Avatar
Default Re: FMU ratio? (AztecEJ)
Yeah, i think i will just get the SMC, since Ivan had a past experienced with FMU. Hey Tom, do you have a Blow-off valve or know somoene who's selling for cheap..
[Modified by 4thGSi, 4:51 AM 3/15/2003]
Old Mar 15, 2003 | 06:51 AM
B18Flip's Avatar
We were thinking of using the fmu to cut the costs down, but everyone seems to agree that it won't be as smooth. The SMC it is then . Oh BTW has anyone used this version yet?
Old Mar 15, 2003 | 09:00 AM
Tomek's Avatar
You made a good choice RJ I used to have an extra 1g DSM BOV but I lost it You can find one cheap, on average they go for like $50
motorhead_guy
Jun 17, 2006 08:49 AM
chirp3rd
Feb 3, 2003 04:56 PM
hybridb18
Oct 7, 2002 10:04 PM
TurbothisLS
Aug 25, 2002 05:39 PM
crxGLASSTOPcrx
Nov 7, 2001 10:13 AM
