which fmu diaphram?
Old Nov 18, 2002 | 09:24 PM
b16ahybrid's Avatar
Default which fmu diaphram?
with my current set-up which diaphram should i run?
b16a, holley 255lph fuel pump,rc 310cc injectors,vortec (6:1) fmu,aem (1:1) adjustable fpr set at 38psi.msd 6al, timing set at 11 degree's, 7psi of boost.
Old Nov 19, 2002 | 02:39 PM
avividmemory's Avatar
Default Re: which fmu diaphram? (b16ahybrid)
**** an fmu, get some bigger injectors...
Old Nov 19, 2002 | 03:19 PM
b16ahybrid's Avatar
Default Re: which fmu diaphram? (SpoolinLS)
This is only until next summer.My car will be coming off the street and set-up for the track.Larger turbo will be ordered this month and hondata is coming next summer after i make my next big purchase (03 silveraldo).Then i will be going with 550cc injectors and ditching the whole fmu set-up.
since i won't be able to keep it off the street (it's just to fun to drive) i'll be tuning it for 11psi (street) and 15psi for the track.
Thanks for the thought, i have already switched to the 8:1 because i checked my plugs and they indicated that i was runing a little lean.
BoostedITR41
Aug 27, 2003 08:26 PM
X2BOARD
Aug 11, 2003 08:18 PM
freeplay
Dec 1, 2002 09:41 AM
FOrSfEd
May 31, 2002 08:53 PM
