Fmu with chipped ecu?
Old Feb 22, 2006 | 03:54 PM
93civciv's Avatar
Default Fmu with chipped ecu?
Just wondering if i still need the fmu with a chipped ecu...my buddy says that i do but i dont think i do..i got an ecu chipped and set up for some 395cc injectors so i would think that is all i need right..?
Old Feb 22, 2006 | 03:58 PM
turboEGhatch's Avatar
Default Re: Fmu with chipped ecu? (93civciv)
Get bigger than 395cc injectors. You're going to probably upgrade in the future, so you might as well go bigger now. If you run properly sized injectors you do not need to run an FMU with uberdata/crome/etc.
Old Feb 22, 2006 | 04:11 PM
93civciv's Avatar
Default Re: Fmu with chipped ecu? (turboEGhatch)
im only running 5psi for the sake of my motor so 395s are what i got...
and im using crome so it pretty much does eliminate the fmu..thats all i needed to know thanks man...
and ill go bigger if the motor blows but for now im good..
Old Feb 22, 2006 | 04:36 PM
beerbongskickass's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93civciv &raquo;</TD></TR><TR><TD CLASS="quote">and ill go bigger if the motor blows but for now im good..</TD></TR></TABLE>
WTF?
If you don't care about your motor give it to me. I'll put it to good use.
Old Feb 22, 2006 | 05:05 PM
Default Re: Fmu with chipped ecu? (beerbongskickass)
I relate that to cutting the top off a condom and saying "I'm only going to expletive her half as long as I normally do, so I'll use the rest of it after I get her pregnant"
Old Feb 22, 2006 | 08:09 PM
93civciv's Avatar
i was told that 395s were good for my setup at 5psi...if the motor blows because of other reason than fuel cuz thats not a problem..then i would upgrade to bigger injectors and all...
Old Feb 22, 2006 | 10:40 PM
HiProfile's Avatar
I don't want to seem like an *** also, but usually you can get up to 550's for just a few bucks more, and up to 850's for no more than 20% more than 395's. 395cc's @42psi fuel would get you 275whp tops, and most stock b16's won't see over that with 10psi on a bigger t3. 5psi with a bigger t3/t04 will get close, but should be okay even if it spikes a few psi.
At most, an adjustable FMU (say 3:1 or 4:1) would be needed for more than 275whp, but those tend to cost as much as injector sets.
Old Feb 25, 2006 | 07:36 PM
93civciv's Avatar
Default Re: Fmu with chipped ecu? (HiProfile)
well i paid 75 for the injectors..brand new...and im really not looking to get some high numbers and all..just wanted that little extra umph....thats why i am only running 5 psi...not really going for record speeds...
commotion
Jun 20, 2006 07:42 AM
Tacoma Luda
Jul 25, 2005 09:47 AM
IDriveHonda
Sep 23, 2004 09:50 PM
Cezilla
Mar 28, 2004 08:21 AM
H23 Power
Jun 25, 2002 08:08 AM
