FMU?
Old Jun 2, 2006 | 04:04 PM
senn1n103's Avatar
Default FMU?
I know it's not smart to run FMU with a turbo setup. That being said, I'm waiting for replies on who does chipping and tuning in AZ. My question is what ratio fmu should I get if I have a 93 del sol. and I'm just going to run 5-6 lbs. of boost. is 10:1 to much?
Old Jun 2, 2006 | 05:59 PM
I3ooS710's Avatar
Default Re: FMU? (senn1n103)
12:1 and you'll be fine. I'd suggest you retard your timing 1-2*..
Old Jun 2, 2006 | 06:17 PM
hondaeg8's Avatar
you can use an fmu with a turbo set up and have no problems. just stay under 8psi and you'll be alright.
use whatever FMU came with the kit. i think most kits come with the 12:1 fmu.
Old Jun 3, 2006 | 10:17 AM
senn1n103's Avatar
Default Re: FMU? (hondaeg8)
Thanks guys. Unfortunatley I didn't buy a kit. I pieced this one together myself. I'm doing this on my own so any other advice (other than don't do it) would be helpful.
Old Jun 3, 2006 | 11:11 AM
hondaeg8's Avatar
whats the full set up?
Old Jun 5, 2006 | 11:43 AM
senn1n103's Avatar
The car is a 93 del sol S. I have a mini-me swap in it. The turbo is a TE04H. I have the adapter plate so it mates with a HF manifold. My friend has a 12:1 fmu, and he has a breggy blue box (not sure what this does), I'll probably buy the stealth mode oil line kit. Everything else is just tuning and piping, right?
Old Jun 5, 2006 | 12:26 PM
JoePSI's Avatar
bov,wastegate,tap oil pan (or buy a moroso pre-tap'd I recommend this, mines very nice),boost guage, intercooler, couplers, t-bolt clamps, keep going!
Old Jun 5, 2006 | 04:13 PM
senn1n103's Avatar
Default Re: FMU? (ENJOYtheRIDE)
Oh yeah, forgot to mention those, thanks.
Old Jun 5, 2006 | 05:01 PM
stewie8apie's Avatar
might want to think about injectors and a fuel pump as well
Old Jun 5, 2006 | 07:57 PM
redface's Avatar
Default Re: FMU? (stewie8apie)
dont use the greddy blue box of death just get a walbro 255 and an fmu you'll be fine i ran my 94 hatch with ls swap t3/t4 at 10 psi. with just a fuel pump and an fmu with absolutely no timing retard on race gas..... on sunoco 94 pump i ran 8 lbs and the olny time i noticed any detonation was when it was 90 degrees out at 10 psi. so just get the fmu and the fuel pump if your doin that way but i do suggest pullin atleast i degree of ignition timing
Old Jun 5, 2006 | 10:08 PM
ctownintegra's Avatar
I'm going with the Blox FMU on 4 psi until I can tune on 10 psi. Should be fine on low low boost. Which Walbro should you get though? High pressure or the regular 255?
Old Jun 5, 2006 | 10:38 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: (ctownintegra)
To OP locash in phoenix is your best bet. Even though your in yuma and thats far for you.
Old Jun 6, 2006 | 12:13 AM
JoePSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ctownintegra &raquo;</TD></TR><TR><TD CLASS="quote">I'm going with the Blox FMU on 4 psi until I can tune on 10 psi. Should be fine on low low boost. Which Walbro should you get though? High pressure or the regular 255?</TD></TR></TABLE>
I'm running the walbro intake 255 which i believe is a high pressure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stewie8apie &raquo;</TD></TR><TR><TD CLASS="quote">might want to think about injectors and a fuel pump as well</TD></TR></TABLE>
Very true, DSM310's for now and RC550's for when its tuned with a walbro255 !
Old Jun 8, 2006 | 04:44 PM
senn1n103's Avatar
Default Re: (00IntegrAllmotoR)
Locash? I think I went to their site, but are they credable?
brasilianstreet
Sep 22, 2004 08:02 PM
BlackDeuceCoupe
Jul 21, 2002 12:52 AM
RTW DC2R
Jun 5, 2002 07:41 AM
