FMIC pipe routing question
Old Feb 22, 2006 | 11:14 AM
haveaNOSday's Avatar
Default FMIC pipe routing question
Just wondering where the typical piping is routed for the fmic on the drivers side.I'm mounting one on my teg and I want to keep the windsheild washer resivoir.do you guys cut a hole in the panel? also do you people remove the bumper beam/support aswell if so how do you re mount the bumper cover after?
Old Feb 22, 2006 | 11:33 AM
dpetro1's Avatar
Default Re: FMIC pipe routing question (haveaNOSday)
ill assume dc chassis, but pretty much you can go under/around the washer res. the piping may hang a little lower but not too bad. then just cut the splash gaurd to fit. kinda depends on what IC you have as well.
kinda like this one, notice it has outlets towards the bottom (pic is of user King Tut33's car)
Old Feb 22, 2006 | 11:40 AM
mike1114's Avatar
Default Re: FMIC pipe routing question (dpetro1)
Find smaller washer res or cut part of yours out of the middle and re seal your resevoir.
Old Feb 22, 2006 | 12:17 PM
actually it's DB, but thanks for the pic I have a better idea now. do you know the average size IC everyone uses for a DB teg. more pics would be greatly appriechiated please
Old Feb 22, 2006 | 12:19 PM
dpetro1's Avatar
Default Re: (haveaNOSday)
depends on your power goals. what kinda HP did you have in mind?
Old Feb 22, 2006 | 12:46 PM
between 280-300 using 2.5 pipes
Old Feb 22, 2006 | 03:10 PM
Dee's Avatar
Dee
70mm piping on my DC2. DC and DB piping are the same.
Old Feb 22, 2006 | 03:19 PM
JDM00SI's Avatar
Default Re: (Dee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dee &raquo;</TD></TR><TR><TD CLASS="quote">70mm piping on my DC2. DC and DB piping are the same.
same set up on my car.
Old Feb 22, 2006 | 10:30 PM
dpetro1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haveaNOSday &raquo;</TD></TR><TR><TD CLASS="quote">between 280-300 using 2.5 pipes </TD></TR></TABLE>
im sure most 6" tall cores would work. im using a revhard 27 x 6 x 3 on my 270whp setup. but i say grab a jrc 8" or precision medium with some room to grow.
Old Feb 22, 2006 | 11:02 PM
sk8shorty012's Avatar
Default Re: (dpetro1)
Johnny Race Car 5" IC (6" would work too)
180 U bend from jcwhitney.com
- kept resevior & no hole in the wall or anything. just cut a little bit of the fender lining away...
oh and heres a pic with the bumper cover back on
Old Feb 23, 2006 | 02:29 AM
great work guys but I don't think I'm down for doing it like that. you guys are not nervous about it rubbing on the floor and possibly breaking the IC? any ways I guess i'l either cut and reseal the ww res. or re locate and just hole saw the wall over here we got some crazy weather and I wouldn't ever think about not running the ww fluid! thanks for the pics BTW.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM00SI &raquo;</TD></TR><TR><TD CLASS="quote">
same set up on my car.</TD></TR></TABLE>
it looks like you cut off the beam,How do you mount the bumper cover after or did you cut until the mounts under the lights? looks clean though.
Modified by haveaNOSday at 6:39 AM 2/23/2006
Old Feb 23, 2006 | 05:18 AM
Dee's Avatar
Dee
Rubbing on the floor? ??
No, I did not remove the silly beam that is on USDM cars. I have a Japanese spec car so came from the factory without a useless mph beam. The front bumper is supported by the triangles below the headlights.
Old Feb 23, 2006 | 06:43 AM
right
broketuner-Sol_Si
Feb 3, 2007 09:39 PM
wrEcKed_LX
Mar 24, 2006 11:53 AM
non-VTEC
Apr 6, 2005 02:30 PM
AspectIndustries
Mar 19, 2004 04:34 PM
PM-Performance
Oct 31, 2003 04:18 AM
