Flywheel Question
Do you guys think i shoud replace my stock flywheel for a aftermarker flywheel?, I'ma be boostin real soon you think its worth replacing it? or stock flywheel could handle the boost? if you guys think i should what flywheels do you think are best in the market? thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheKingPin »</TD></TR><TR><TD CLASS="quote">Well. I say go for it. I have the fidanza in my lude right now, pretty good. It'll help you get to full boost sooner.</TD></TR></TABLE>
my experience is, if you go too light it hinders your ability to get out the hole.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unbanned_evosol »</TD></TR><TR><TD CLASS="quote">
my experience is, if you go too light it hinders your ability to get out the hole.</TD></TR></TABLE>
Sorry man. Seriously, that went right over my head. Could you explain a little?
My buddy has a 2000gsr w/ drag kit, 9lb flywheel, lsd.
even with the lsd it is nearly impossible to get a decent consistent launch, mostly because you would have to "over shoot" the rev target so that you could try to get a good launch, which would result in spinning your *** off. If you tried to launch at a lower rpm it would just bog off the line. I firmly believe its due to the loss of rotational mass inertia of the lightened flywheel.
on my set up, i have a middle of the line 12lbs and it launches and revs just beautifully.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unbanned_evosol »</TD></TR><TR><TD CLASS="quote">My buddy has a 2000gsr w/ drag kit, 9lb flywheel, lsd.
on my set up, i have a middle of the line 12lbs and it launches and revs just beautifully.</TD></TR></TABLE>thats why i asked if hed be draggin. You are right, too light a fly will kill any launch consistancy but hiway races =
should i stick with the stock b16 flywheel?, would the stock cause launching problems?
my setup right now is a exedy stage 2 cerametalic clutch and pressure plate with a quaife lsd
