fluttering blow off valve?
Old Oct 23, 2002 | 06:17 PM
WONG FRIED RICE's Avatar
Default fluttering blow off valve?
i have a SOHC vtec/turbo set up. D16y7/8 motor. .0020 mm thicker head gasket, ported head, 5 angle valve job, adjustable cam gear, high flow fuel pump, adj. fuel regulator, exhaust. When i boost, my blitz ssqv flutters when it purges. is it supposed to sound like that? I purge it at any boost level, and its the same..flutter flutter. <shrug>
Old Oct 23, 2002 | 06:18 PM
Etylorcen's Avatar
Default Re: fluttering blow off valve? (JDMB16ACRX)
Have you tried loosening it?
Old Oct 23, 2002 | 06:24 PM
Default Re: fluttering blow off valve? (Etylorcen)
yup loosened, tightened. same o same o.
Old Oct 23, 2002 | 06:55 PM
FUP23's Avatar
New User
mine does the exact same thing only on like 1 lbs or 2 lbs
Old Oct 23, 2002 | 06:59 PM
Default Re: fluttering blow off valve? (Devin17)
do you have a air filter connected to your turbo?
Old Oct 23, 2002 | 07:10 PM
B18EG6's Avatar
I think its just the noise that it was meant to make...kinda like psshs shhs shhhs shhsh shs
edit: here I have this video of a gsx-r bike pushing 30 psi on my school webbysite...does your bov sound like this? This is what my Blitz ss sounds like...
http://students.salisbury.edu/~sas0661/gsxr.mpeg
RIGHT CLICK, THEN SAVE TARGET AS...
[Modified by B18EG6, 11:12 PM 10/23/2002]
Old Oct 23, 2002 | 07:43 PM
Default Re: fluttering blow off valve? (B18EG6)
yea...that is what it sounds like...sorta....i guess its the way it is
Old Oct 23, 2002 | 07:49 PM
tony1's Avatar
Sounds like it's not opening soon enough and the turbo is backing up a little. Check your vacuum source. You might need to give the bov it's own source without anything tee'd in to it.
Old Oct 23, 2002 | 08:04 PM
Default Re: fluttering blow off valve? (tony1)
hmm...thats a good idea...i will check that
Old Oct 23, 2002 | 09:46 PM
turbologist's Avatar
I used to have one it wouldnt open at all. I actually had to take it apart and relube it and it worked fine after that.
Old Oct 23, 2002 | 09:49 PM
shadowdawn's Avatar
Default Re: fluttering blow off valve? (drealboostedhybrid)
My vortech did that for months, tried ALOT of different methods of tight/loose... eventually I loosened it nearly all the way and now it sounds REAL nice, no more dead bird under the hood sound...
Old Oct 23, 2002 | 10:52 PM
wrXtian's Avatar
Default Re: fluttering blow off valve? (shadowdawn)
sometimes that fluttering is just the wastegate.. u might have ur spring in ur blow off valve too tight and it's not opening up.. i had the same problem.. i thto something was wrong w/ my bov until i loosened the spring.. it turned out the whole time i was hearing a wastegate..
Old Oct 24, 2002 | 06:54 AM
Default Re: fluttering blow off valve? (xjdm94x)
if its the wastegate....what can i do to remedy that?
hellsyea2020
11
Feb 7, 2007 02:30 PM
Turbochargedcivic
25
Jul 31, 2006 02:26 PM
c61lude
Oct 11, 2005 12:46 PM
dc2pffsssttt
Mar 31, 2003 01:55 PM
cinq
Oct 14, 2002 06:56 PM
