Floating Wrist Pin????
Old Dec 20, 2004 | 02:51 PM
Ls InTeGrA RaCeR's Avatar
Default Floating Wrist Pin????
Ok I just got these new Wiseco 9:3-1 Pistons for my 99 Ls and they have a floating wrist pin. Is this going to be ok since the stock pistons only had the standard lock pin? What could happen if I put these pistons in? Good/Bad?
Old Dec 20, 2004 | 03:17 PM
IN VTEC's Avatar
Default Re: Floating Wrist Pin???? (Ls InTeGrA RaCeR)
OEM Honda B-series piston/rod combos don't use any sort of wire lock and only the pistons float. The wrist pin is interference fit with the small-end of the rod.
I've seen JUN forged pistons used with stock P72R rods, so it might not be totally out of the question to use them with OEM Honda rods.
Check the wrist pin to piston clearance. I believe the usual amount of clearance is right around half a ten-thou to a thou.
Old Dec 20, 2004 | 04:49 PM
mamaboy's Avatar
your fine
Old Dec 20, 2004 | 05:16 PM
Default Re: Floating Wrist Pin???? (mamaboy)
see I was wondering if this is one of those pistons that require you to replace your rods......I'm trying to avoid that (money issues).
Old Dec 20, 2004 | 06:27 PM
anyone else????
Old Dec 20, 2004 | 08:00 PM
atcrx's Avatar
You will be ok to use the stock rod with these pistons just press the wrist pin into your stock rod that is where the interference fit is. then u do not have to use the lock rings. they are only for use with rods that have a bushed end.
Old Dec 21, 2004 | 01:34 AM
Default Re: Floating Wrist Pin???? (atcrx)
ok, I'll be taking everything in to the shop in a day or two.
Old Dec 21, 2004 | 06:20 AM
IN VTEC's Avatar
Just make sure they know (without a doubt) which way the pistons go on the rods.
nenetech
Jan 2, 2013 09:01 PM
terrorhawk
11
Jan 18, 2012 02:28 AM
thumper64
Nov 4, 2009 11:58 AM
ys1civicsi
Feb 19, 2008 06:23 PM
eg6madness
Apr 12, 2007 03:55 AM
