Flashing Check engine light
Old Nov 23, 2001 | 01:00 PM
HiGhCaM's Avatar
Default Flashing Check engine light
Check engine light flashing?
Old Nov 23, 2001 | 01:10 PM
dbman96's Avatar
New User
Default Re: Flashing Check engine light (HiGhCaM)
Mine is. Anyone else?
Old Nov 23, 2001 | 01:20 PM
GSRacer's Avatar
New User
Default Re: Flashing Check engine light (dbman96)
me to
Old Nov 23, 2001 | 01:32 PM
HiGhCaM's Avatar
Anyone know the difference betweed flashing and solid on?
Old Nov 23, 2001 | 10:08 PM
VaporTrail's Avatar
New User
is it a steady flash, or does it flash long, then short flashes?
Old Nov 23, 2001 | 10:19 PM
HiGhCaM's Avatar
Default Re: Flashing Check engine light (VaporTrail)
Flashes when driving non stop shut car off and its gone then drive more. Easy driving and then later flashes. no codes unless it stays on. usually after flashing is done. and then the codes are 71 through 74 in no partictular order. Is anybody here a Honda Cert Tech?
Old Nov 23, 2001 | 10:51 PM
VaporTrail's Avatar
New User
that's a cylinder misfire code. You are either running too rich, or too lean. Check your spark plugs for signs of detonation or other problems with combustion. Make corrections (lowering boost, regapping plugs, adding fuel, taking away fuel) as needed. Then reset the ECU.
Old Nov 24, 2001 | 06:52 AM
FIxALPHA's Avatar
Im not here to scare anyone, but I have a couple of questions....
Does your car feel or sound?
Does any smoke come out of the valve cover breather?
This happend to me in the beg. of the season (April 01) on the way home from the track. The CEL started to flash while I was driving and when I shut the car off, the flashing CEL dissapears.
I pulled over to a gas station and saw smoke (white) coming out of the valve cover breather.
The next day took the motor apart and found #3 cyl. with cracked ring lands.
Just wanted to share my story, hopefully thats not the case with your cars.
Old Nov 26, 2001 | 05:56 PM
integRated109's Avatar
Default Re: Flashing Check engine light (FIxALPHA)
haha, i just did the same thing, but im on cylinder 1. maybe i shoulda listened to all those people that said 8psi was too high on a stock b18c5 it only smoked that day, but im still getting my misfire codes. just gives ya a reason to build it
khmersouljah
Sep 23, 2010 12:03 PM
alfiler
Feb 16, 2009 11:55 PM
Ed 341
Mar 8, 2006 02:45 PM
99IntegraGS
May 3, 2004 07:18 AM
rad_thundercat
Apr 21, 2004 08:20 PM
