Fjo injector Driver wiring
Old May 4, 2006 | 02:19 AM
  #26
DaveF's Avatar
Default Re: Fjo injector Driver wiring (willie_su2166)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by willie_su2166 &raquo;</TD></TR><TR><TD CLASS="quote">can anyone confirm if this wiringis correct.?</TD></TR></TABLE>
well you are powering the fjo box, then giving it injector sig/power. it goes out to the injectors to give them power/sig also. it looks like it would work.
the only thing im worried about is the yel/blk you cut at the ecu (injec common) i believe that might also power a few other things in the engine bay. like the iac. its been awhile since ive had and engine harness apart.
Old May 5, 2006 | 06:31 AM
  #27
willie_su2166's Avatar
Default Re: Fjo injector Driver wiring (PSIPRO4)
It is true that y/b also power other thing, but if you cut it just couple inch from injector clips, it should not affect anything.
Old May 5, 2006 | 06:45 AM
  #28
iBrandon's Avatar
Anyone have the diagram for 18 wire setup? I have the old one...
Old May 5, 2006 | 11:37 AM
  #29
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by willie_su2166 &raquo;</TD></TR><TR><TD CLASS="quote">It is true that y/b also power other thing, but if you cut it just couple inch from injector clips, it should not affect anything. </TD></TR></TABLE>
right, the yelow blacks that come from the injector, go into a dead end plug, which is power'd by the ecu, and also sends signal to the iac valve, and i belive 1 or 2 other things but im not 100% . if you cut the yelow/blk's at the injector you are in the clear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iBrandon &raquo;</TD></TR><TR><TD CLASS="quote">Anyone have the diagram for 18 wire setup? I have the old one...</TD></TR></TABLE>
this diagram below should work for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by willie_su2166 &raquo;</TD></TR><TR><TD CLASS="quote">this is what I did, and the car run fine. actually the car just finished a new dyno pull yesterday.
the drawing is suck, but it may help to clean things up. also please correct me if I am wrong. and also I have y/b cut
99thwondah
13
Mar 20, 2015 01:40 PM
streetjdmrex
Mar 21, 2014 10:39 AM
littlebill
Mar 17, 2007 09:20 PM
RACEPAK
Oct 4, 2005 05:57 AM
CTRwannaB
Jun 8, 2003 04:11 PM
