Fjo injector Driver wiring
Old Apr 27, 2006 | 03:23 PM
willie_su2166's Avatar
Default Fjo injector Driver wiring
anyone here can help me with the fjo injector driver wiring?
Old Apr 27, 2006 | 03:25 PM
cluelessmale's Avatar
Default Re: Fjo injector Driver wiring (willie_su2166)
new or old one
Old Apr 27, 2006 | 03:26 PM
Default Re: Fjo injector Driver wiring (cluelessmale)
new one
Old Apr 27, 2006 | 03:28 PM
good luck, chad(underpressure02) tried wiring it up and it never worked. we end up just using the resistor box.
if you want PM him he might be able to help
Old Apr 27, 2006 | 04:46 PM
According the manual
A-white ---???
B-white/red---injector #1
C-white/orange—injector#2
D-white/yellow—injector#3
E-white/green—injector#4
A-white—ignition power (A21)
B-Red—injecotr#1 from ecu (A1)
C-Orange— injecotr#2 from ecu (A3)
D-yellow— injecotr#3 from ecu (A5)
E-Green— injecotr#4 from ecu (A2)
F-Pink--?????
Final battery Power +12V
Ground.
Can someone help me with “???”
am I on the right track?
Thanks
Will
Old Apr 27, 2006 | 05:14 PM
Old Apr 27, 2006 | 05:25 PM
Turbocivic94's Avatar
There is fjo guy here, you should ask him
Old Apr 27, 2006 | 05:36 PM
Default Re: Fjo injector Driver wiring (Turbocivic94)
I called him early today, but still confused though
Old Apr 27, 2006 | 05:55 PM
D-tuned's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by willie_su2166 &raquo;</TD></TR><TR><TD CLASS="quote">According the manual
A-white ---??? This wire going to the other side of each injector
F-Pink--????? hook this wire up to switched +12V
Ground.
Thanks
Will
Old Apr 27, 2006 | 06:02 PM
Default Re: Fjo injector Driver wiring (D-tuned)
D-tuned, so you are saying wiring all four yellow/back wires off four injectors into one white wire?
also, can this be wire up to a ignition power (A21)?
Old Apr 27, 2006 | 06:18 PM
DaveF's Avatar
find a dead end plug you might have laying around and use it.
put the A & F as well as the 4 yel/blks from the injectors in it
Old Apr 27, 2006 | 09:30 PM
Default Re: Fjo injector Driver wiring (Dturbocivic)
Thanks for any advices, also wiring is done already, and will try to fire it up tomorrow.
Old Apr 28, 2006 | 05:53 AM
underpressure02's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">find a dead end plug you might have laying around and use it.
According to FJO that is not correct what you said.
A white common should go to one side of all the injectors.
A. White ign power and F pink power can both be rigged up to a 12 volt switched ign.
Old Apr 28, 2006 | 02:11 PM
DaveF's Avatar
Default Re: Fjo injector Driver wiring (underpressure02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 &raquo;</TD></TR><TR><TD CLASS="quote">
A. White ign power and F pink power can both be rigged up to a 12 volt switched ign. </TD></TR></TABLE>
white(OUT) should go to one side of all the injectors. so. like i said. get a dead end plug. put the white in it. then put all 4 yel/blk's coming from the injectors in it as well. so you have 5 wire total in it.
you can power your fjo with the yel/blk off the ecu
Old Apr 29, 2006 | 07:28 AM
Here is how I do...
A-white ---connect all 4 yellow/black from injector side into this white wire.
F-Pink--connect all 4 yellow/black from ecu side into this pink wire
Ground.
also make sure a to a, b to b, c to c.....and car start right up. Correct me if I am wrong.
Old Apr 29, 2006 | 11:30 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by willie_su2166 &raquo;</TD></TR><TR><TD CLASS="quote">Here is how I do...
Ground.
also make sure a to a, b to b, c to c.....and car start right up. Correct me if I am wrong. </TD></TR></TABLE>
Well did the car start up?
Old Apr 29, 2006 | 06:31 PM
DaveF's Avatar
not sure what you mean right here?
ECU--(IN)--- FJO---(OUT)---injector
Old Apr 29, 2006 | 07:08 PM
I don't understand how that will work with the pink wire.
Old Apr 29, 2006 | 07:24 PM
DaveF's Avatar
I don't understand how that will work with the pink wire. </TD></TR></TABLE>
its a yel/blk coiming out of the ecu, just tap into it, dont cut it.
Old Apr 29, 2006 | 07:38 PM
its a yel/blk coiming out of the ecu, just tap into it, dont cut it. </TD></TR></TABLE>
That is what we tried when we wired mine up and it did not work. That is why guy from fjo told me to wire the pink right to my ign power
Old Apr 30, 2006 | 05:46 AM
DaveF's Avatar
That is what we tried when we wired mine up and it did not work. That is why guy from fjo told me to wire the pink right to my ign power</TD></TR></TABLE>
im sure it wasnt the fjo problem. did you bother to test anything with a test light o multi meter to check for voltages @ differant wires.
Old Apr 30, 2006 | 05:57 AM
im sure it wasnt the fjo problem. did you bother to test anything with a test light o multi meter to check for voltages @ differant wires.</TD></TR></TABLE>
Yes tested everything with the volt meter and also check for continunity from the each wire to each injector.
Old Apr 30, 2006 | 07:03 AM
DaveF's Avatar
Yes tested everything with the volt meter and also check for continunity from the each wire to each injector.</TD></TR></TABLE>
what did you find out ???? were the injectors getting power from the fjo?
Old Apr 30, 2006 | 09:11 AM
this is what I did, and the car run fine. actually the car just finished a new dyno pull yesterday.
the drawing is suck, but it may help to clean things up. also please correct me if I am wrong. and also I have y/b cut
Old May 3, 2006 | 06:38 PM
can anyone confirm if this wiringis correct.?
