Fixed my Rev Limiter PROBLEM with Hondata!!!!!!!!!!!!!!!!
Well if anyone looked at my other post about me getting a rev limiter at 4800-5000 rpm after running the car hard and boosting. https://honda-tech.com/zerothread?id=637265 Well we went into my current ROM and changed one BAD SPOT in my fuel BUT this did not correct the problem. DOH! Well we FINALLY changed out the Blue Box and I boosted hard up to 9000rpm in 2nd,3rd gear and part of 4th gear hitting about 15psi, Unforunatley we were unable to datalog since this particular blue box does not have the Hondalogger option
. Well I did the runs over and over and over again and NOTHING no boost cut no rev limiter NOTHING! Thank God! We did change the Blue Box and the Ribbon at the same time but are pretty POSITIVE it is the Blue box and not the ribbon. Will do some testing on that as well. Could not see it being the ribbon since when it happens we turn the car off and restart it and problem was solved previously until we boosted hard again. I will post more results with swapping the ribbon out to test that out also. Thanks for everyones input on my problem. FYI this is the first time actually since my car made 581.9whp and 381 ft-lb torque but that was at 28psi, I am running 15psi and that is about 400whp AND IT FEEL'S GOOD!!!!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase »</TD></TR><TR><TD CLASS="quote">glad its fixed, but too bad you're still gay
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo »</TD></TR><TR><TD CLASS="quote">I'll tell fredo you are happy.
He has something for your PIEHOLE! LOL!
=ART
</TD></TR></TABLE>He has something for your PIEHOLE! LOL!
=ART
Congrats Terry. Im glad to see you fixed the problem. Hopefully all of the little gremlins are out of the car. You need to get some track times posted up you 10 second *****!!!!!!
Hey one thing to check if you get bored one day and wanna **** with your old blue box...
Check and see what the LED is doing as you drive it. See if it stays solid red or flashes. That's how I found out my ribbon was bad, but the same symptoms will pop up if the blue box is junk as well.
Well have someone with you at least... looking over @ a box while beating the **** out of a 500+ whp car is a little insane and dangerous...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted99Si »</TD></TR><TR><TD CLASS="quote"> You need to get some track times posted up you 10 second *****!!!!!!
Hes only an 11.9 ***** for the time being.
</TD></TR></TABLE>Hes only an 11.9 ***** for the time being.
If you do have a problem with your Blue Box will hondata fix it? Are they good at backing up there product?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BodyKits NW »</TD></TR><TR><TD CLASS="quote">If you do have a problem with your Blue Box will hondata fix it? Are they good at backing up there product? </TD></TR></TABLE>
I called today and talked to the girl who answered the phone and she said to send it back with a note explaining the problem and my contact info and they would take it from there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sung »</TD></TR><TR><TD CLASS="quote">that blue box must be special! </TD></TR></TABLE>
Nah I heard that some asian guy let him borrow it... So it's not special...lol
Boostfed
Nov 1, 2003 05:39 AM
Boostfed
Oct 15, 2003 10:41 AM
92HB_HB
Mar 4, 2002 05:51 PM
BOOST! Boostfed
