-AN fitting/line size for Catch Can & Crankcase evacuation
Old May 1, 2006 | 07:13 PM
.dave's Avatar
i HAS questions ?
Default -AN fitting/line size for Catch Can & Crankcase evacuation
For those of you with -AN lines running off the valve cover, what size fittings and line did you use? I'm going to be welding some fittings onto my valve cover very soon, and need to know what a good size would be. I'm thinking -10 AN would be a good size. Any thoughts?
Old May 1, 2006 | 07:24 PM
adictionbass's Avatar
Default Re: -AN fitting/line size for Catch Can & Crankcase evacuation (daveG)
post pics too, Im going to be doing the same thing
Old May 1, 2006 | 10:41 PM
V-SPEC 1's Avatar
Default Re: -AN fitting/line size for Catch Can & Crankcase evacuation (rota92)
I used -8 for mine, big enough.
Old May 1, 2006 | 10:50 PM
accordking's Avatar
2 -8's works for me.
Old May 2, 2006 | 04:30 AM
mike1114's Avatar
Default Re: -AN fitting/line size for Catch Can & Crankcase evacuation (accordking)
2 -12's for me.
I'll post pics in a bit.
Old May 2, 2006 | 05:42 AM
DaveF's Avatar
Default Re: -AN fitting/line size for Catch Can & Crankcase evacuation (mike1114)
-16 an
Old May 2, 2006 | 06:09 AM
kKdARIAN's Avatar
Vice President/CEO
Default Re: -AN fitting/line size for Catch Can & Crankcase evacuation (PSIPRO4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PSIPRO4 &raquo;</TD></TR><TR><TD CLASS="quote">-16 an </TD></TR></TABLE>
Old May 2, 2006 | 07:07 AM
awdgsx96's Avatar
Default Re: -AN fitting/line size for Catch Can & Crankcase evacuation (kKdARIAN)
Wow, -16, that isn't overkill?
Old May 2, 2006 | 07:08 AM
raiden571's Avatar
can u say over kill??....but it looks so ******* cool
edit:based on the way ur mani looks, im assuming the whole setup is like that
Old May 2, 2006 | 09:16 AM
Default Re: -AN fitting/line size for Catch Can & Crankcase evacuation (raiden571)
does anyone just have barbs and some sort of rubber fuel line running of the valve cover?
Old May 2, 2006 | 09:24 AM
N20civicB18's Avatar
Default Re: -AN fitting/line size for Catch Can & Crankcase evacuation (adictionbass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass &raquo;</TD></TR><TR><TD CLASS="quote">does anyone just have barbs and some sort of rubber fuel line running of the valve cover?</TD></TR></TABLE>
Im sure people do, probably find something on homemadeturbo.com
Old May 2, 2006 | 10:58 AM
kevino002's Avatar
Default Re: -AN fitting/line size for Catch Can & Crankcase evacuation (N20civicB18)
I went with 2 -6's, I could have gone bigger, but I got the fittings for free...
Old May 2, 2006 | 02:20 PM
.dave's Avatar
i HAS questions ?
Ladysman does I believe. I was thinking of using the Russell push lock or twist lock (whatever its call fittings). They're rubber hoses with an -AN connection.
Old May 2, 2006 | 02:50 PM
Fitti's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raiden571 &raquo;</TD></TR><TR><TD CLASS="quote">can u say over kill??....but it looks so ******* cool
edit:based on the way ur mani looks, im assuming the whole setup is like that </TD></TR></TABLE>
Yeah looks as if this their car has a Mid plate on it as well
Old May 2, 2006 | 04:51 PM
Default Re: -AN fitting/line size for Catch Can & Crankcase evacuation (Fitti)
Altenator is on the front too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fitti &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah looks as if this their car has a Mid plate on it as well</TD></TR></TABLE>
Old May 2, 2006 | 06:22 PM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daveG &raquo;</TD></TR><TR><TD CLASS="quote">Ladysman does I believe. I was thinking of using the Russell push lock or twist lock (whatever its call fittings). They're rubber hoses with an -AN connection.</TD></TR></TABLE>
You can get the line at lowes. It is reinforced line.
Old May 3, 2006 | 04:47 AM
mike1114's Avatar
Default Re: -AN fitting/line size for Catch Can & Crankcase evacuation (ladysman)
the reinforced hose ladysman pictured will not hold up near the turbo manifold, EVEN inside a firesleeve. Mine melted that kind of hose inside the firesleeve.
Near the turbo mani stainless line is the only way to go.
Off the back of block or valve cover, heater hose, that reinforced hose that ladysman posted, or any type of hose really is fine.
Old May 3, 2006 | 06:50 AM
BoostedEG6's Avatar
I am running 3 -10's on my car.... two on the front and one in the stock breather location.... here are some pics
[img]
Old May 3, 2006 | 07:15 AM
kordenbrock motorsports's Avatar
-10AN would be ideal...no issues here. get some braided line to top off the sundae....best of luck
brett
(check our website out ...we make these systems...) http://www.kms-fab.com
Old May 3, 2006 | 07:24 AM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">the reinforced hose ladysman pictured will not hold up near the turbo manifold, EVEN inside a firesleeve. Mine melted that kind of hose inside the firesleeve.
Off the back of block or valve cover, heater hose, that reinforced hose that ladysman posted, or any type of hose really is fine.</TD></TR></TABLE>
Mike is completely right. I should have noted that. Thanks Mike!
I have smelled this stuff melt and it smells like burnt bandaids.
HOw are you guys drilling the valve cover by the way? My engine came like this from Endyn. Are you putting baffles in the front? Anyone got pics?
Old May 3, 2006 | 08:43 AM
may people will use a 1/2" NPT bung and weld it onto the valve cover...all i have done, as well as our other cars, is simply drill and tap the valve cover directly. the valve cover does have internal baffling, right where the holes are. i can try and get some pics up tonight if you would like
brett
Old May 3, 2006 | 09:57 AM
mike1114's Avatar
There is baffles there already in the front of the valvecover.
I'm not sure how my welder put the holes there.
Old May 3, 2006 | 01:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">There is baffles there already in the front of the valvecover.
I'm not sure how my welder put the holes there.</TD></TR></TABLE>
have pics yet?
Old May 3, 2006 | 04:42 PM
mike1114's Avatar
Old May 3, 2006 | 05:33 PM
Dunc's Avatar
BCICAN
Default Re: (kordenbrock motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kordenbrock motorsports &raquo;</TD></TR><TR><TD CLASS="quote">-10AN would be ideal...no issues here. get some braided line to top off the sundae....best of luck
brett
(check our website out ...we make these systems...) http://www.kms-fab.com</TD></TR></TABLE>
+1 for an honest local guy
PSIPRO4: Any reason why you went with -16?
