Fitment issues with 3" AC downpipe
Old Jul 9, 2005 | 01:26 PM
rocket256's Avatar
Default Fitment issues with 3" AC downpipe
Sup all, I have a lil problem. I ordered a Nuekin man./ DP some months ago. When I received it I looked everything over and put it back in the box. Now that I have all my new upgrades and saved up enough money to get it all put on I notice that on the down-pipe the bend is so great that I cant get to the 5th bolt in on the DP. What do I or can I do to fix this?
Old Jul 9, 2005 | 01:32 PM
drumking15's Avatar
use a stud and nut
Old Jul 9, 2005 | 02:01 PM
rocket256's Avatar
Default Re: (drumking15)
its so tight i dont think you can get a nut in between there.
Old Jul 9, 2005 | 02:12 PM
95GSRTT
Guest
Posts: n/a
Default Re: (rocket256)
lol looking at that picture i dont think you could either. Kinda defeats the purpose of having a full 3" if you cant mount it.
Old Jul 9, 2005 | 02:35 PM
rocket256's Avatar
Default Re: (95GSRTT)
I know! I was all ready to get it retuned this coming Wed. but now this
Old Jul 9, 2005 | 02:50 PM
inspyral's Avatar
You might be able to get away with just using the other 4 holes, but it'll probably leak without a gasket. You can try one of the dp gaskets that RRE makes, and that might be enough to seal with 4 bolts:
Either that or send it back and have them make you a new one.
Old Jul 9, 2005 | 03:48 PM
s2kdre's Avatar
Default Re: (inspyral)
just put a stud in that hole so u wont have a leak
Old Jul 9, 2005 | 04:52 PM
mrbsponge's Avatar
i have damn near the same problem and only run 4 of the 5 bolts and have no issues even without a gasket
Old Jul 9, 2005 | 05:00 PM
GeeGee's Avatar
are you sure you got it from Neukin? b/c the welds do not look so good, neither does the craftmanship.
Old Jul 9, 2005 | 05:17 PM
FOrSfEd's Avatar
Default Re: (Krabbypro)
I only have 4 bolts in mine and it does leak.
Old Jul 9, 2005 | 06:14 PM
rocket256's Avatar
Default Re: (FOrSfEd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Krabbypro &raquo;</TD></TR><TR><TD CLASS="quote">are you sure you got it from Neukin? b/c the welds do not look so good, neither does the craftsmanship. </TD></TR></TABLE>
Yes; I got it from Nuekin. You want to see my bill of sale
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOrSfEd &raquo;</TD></TR><TR><TD CLASS="quote">I only have 4 bolts in mine and it does leak.</TD></TR></TABLE>
How bad did it leak? What did you do to fix it?
FortunateFool.'s Avatar
Couldnt you tap that hole and just snug it up entill future work could be done
Old Jul 9, 2005 | 06:26 PM
rocket256's Avatar
Default Re: (FortunateFool.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FortunateFool. &raquo;</TD></TR><TR><TD CLASS="quote">Couldnt you tap that hole and just snug it up entill future work could be done</TD></TR></TABLE>
you can barley get a pencil in between the bend and the plate
Old Jul 9, 2005 | 06:41 PM
From the other side though ?? Just tap aset of threads in there ??
Old Jul 9, 2005 | 07:32 PM
GeeGee's Avatar
there is no way anything is going in there. I have have made plenty of downpipes and this is the kinda of thing i try to avoid. You either have to go with a new downpipe or run 4 bolts. It doesn't even look like it has enough room for a nut, if it does you could put a stud on the turbo, then put a nut in and tighten up the nut as you push the flange in.
Old Jul 9, 2005 | 07:41 PM
No what Im saying is ..with the DP off tap the hole a size bigger to make some threads for a bolt to screw into. Theres plenty off room on the other side not the smushed up side.
Old Jul 10, 2005 | 10:19 PM
lodo1's Avatar
ouch, that looks like poo. hope you didnt spend too much on it, or hope the guys at neukin will redo it for ya. thats pretty much impossible to do anything with
Old Jul 11, 2005 | 01:46 AM
AspectIndustries's Avatar
Default Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">i have damn near the same problem and only run 4 of the 5 bolts and have no issues even without a gasket</TD></TR></TABLE>
Same here. Works fine for me.
Old Jul 11, 2005 | 04:02 AM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: (synik)
id take a dremel and dremel down the flange enough to fit a nut in ther and put a stud in the turbo then you should be fine
Old Jul 11, 2005 | 04:32 AM
igo4bmx's Avatar
im really suprised someone made that and didn't even bother to think about how a nut would fit on there!!
i would say another solution is to cut the DP and get a v band setup going...
then bolt up the flange then vband the rest of the piping...
Old Jul 11, 2005 | 05:43 AM
rocket256's Avatar
Default Re: (igo4bmx)
I talked to Alex and he said that "it has been decked so I will be fine with running olny 4 bolts!"
Old Jul 11, 2005 | 05:46 AM
Rod.'s Avatar
Default Re: (synik)
i ran 4 out of 5 bolts on my last setup with no leak
Old Jul 11, 2005 | 06:17 AM
CRX T-Si's Avatar
Default Re: (Rod.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rod. &raquo;</TD></TR><TR><TD CLASS="quote">i ran 4 out of 5 bolts on my last setup with no leak</TD></TR></TABLE>
I agree.....I only have 4 bolts on mine also. It's not necessary to have all 5 bolts/nuts. Go with 4 man..you'll be just fine.
Who ever said put a nut in there...well your nutz. Anyone can see that there is no room even if there is room for a nut how in the world will you turn it?
Old Jul 11, 2005 | 07:37 AM
MrBui's Avatar
Default Re: Fitment issues with 3" AC downpipe (rocket256)
i sprayed copper spray on mine and only used 4 bolts...so far so good
Old Jul 11, 2005 | 07:46 AM
notoriousB's Avatar
Default Re: (coptzer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coptzer &raquo;</TD></TR><TR><TD CLASS="quote">id take a dremel and dremel down the flange enough to fit a nut in ther and put a stud in the turbo then you should be fine </TD></TR></TABLE>
I'm with you ^^^ that flange looks really thick you should be able to grind some of it off to fit a nut in there.
