First time gsr build
Old Jan 19, 2008 | 07:36 PM
tmar253's Avatar
Default First time gsr build
I recently decided to build my motor for turbo, just wanted to get some advice on engine parts that aren't on my list that would help me achieve my goal high 11's.I know the hp numbers and 1/4 mile time depend on the type of turbo setup you run just want see if the parts i have and the machine work will support a turbo setup that is capable of putting down that much power. I have also including a list of the machine work that i plan on getting, please add your thoughts and tips on the build, here is what i will be using
Parts I have
The Block
Stock gsr block
Stock crank
Eagle H-beam rods
Weisco 81.5mm 8.6-8.9 pistons
Acl Rod bearings, main bearings & thrust washers
The Head
Arp head studs
New OEM valves
Skunk2 titanium retainers
Skunk2 dual springs
Parts that i may need
Cams?
Intake manifold?
Throttle body?
Machine work
Bottom end
Bore & hone .50 over
Clean block & glass bead
Micropolish & balance crank
Deck Block
Head
Clean head & glass bead
3 Angle valve grind
Mill head
port & polish?
Misc Parts
Cylinder head gasket set
Cometic 81.5mm head gasket
What thickness?
Bottom end gasket set
OEM timing belt
Tensioner
Water pump
Thermostat
Oil pump
Clutch & Lightened flywheel kit
What’s a good brand?
I haven't decided what turbo kit to go with yet if you have any suggestions please let me know. I want to get the engine build out of the way then focus on putting the turbo kit together. Again please list any suggestions on parts,machine work or helpful tips on the build.
Thanks
Old Jan 19, 2008 | 07:39 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: First time gsr build (tmar253)
all that stuff looks good, what do you plan on using for fueling (management and fuel pump) ?
Old Jan 20, 2008 | 11:31 AM
tmar253's Avatar
Default Re: First time gsr build (boostedcivicsir)
i haven't researched my options do you have any suggestions?
Old Jan 21, 2008 | 03:20 AM
Mr. Badwrench
hondata s300 w/ boost.
Old Jan 21, 2008 | 07:55 AM
boostedh22lude1's Avatar
go with the hondata
andyman97
Oct 27, 2015 10:22 AM
BluePrintmfg.com
50
Apr 23, 2009 08:09 AM
sinister357
Nov 27, 2007 04:11 PM
11SECEG
Northern California (Sales)
Jul 25, 2006 09:30 PM
jdmjeff
11
Mar 27, 2006 10:48 PM
