first time at the 1320...
Old Oct 13, 2002 | 09:39 PM
CM-R's Avatar
Default first time at the 1320...
How can I improve my et's...I'm running BFG g-force T/A I didn't even burn out on them in the water box...should I ? Here's what I got for my first 1/4 mile time at the drag strip...with my completely full interior drag 3 gsr...i didn't even have that good of traction with the bfg's i guess i gas it to much or something. I two steped at 5,100 and slipped the clutch
reaction: .717
I1: 2.282
I2: 6.108
I3: 9.155
(I3) MPH: 82.599
I4: .000
E.T: 13.896
MPH: 105.580
Old Oct 13, 2002 | 11:21 PM
mos's Avatar
mos
Default Re: first time at the 1320... (CM-R)
Thats pretty good. I hope my crappy setup can run times like that. What kind of pressure were you running in the tires? Maybe post this is the drag forum too.
Old Oct 14, 2002 | 12:42 AM
IntegD's Avatar
New User
Default Re: first time at the 1320... (mos)
you should heat them up...how much psi??
Old Oct 14, 2002 | 06:13 AM
tmg's Avatar
tmg
good times, maybe you should try the drag section.
Old Oct 14, 2002 | 07:14 AM
DIRep972's Avatar
Smarter than you
you need to heat those up. you should be hitting consistant 2.0 60fts on those tires. just get em wet in the water, roll out to the dry and do a big 2nd gear burn out with alot of white smoke. 2.0's should come easy.
Old Oct 14, 2002 | 10:02 AM
CM-R's Avatar
Ok thanks guys. I had the drag radials at 20 psi. Next time i'm going to heat them up good and try 15 psi tire pressure...
H22Stew
Feb 2, 2008 05:44 PM
TravSi
Aug 11, 2003 01:50 AM
CM-R
Oct 23, 2002 06:35 PM
Type R 702
Oct 20, 2001 11:57 AM
