first time at the 1320....
Old Oct 21, 2002 | 08:44 PM
CM-R's Avatar
Default first time at the 1320....
How can I improve my et's...I'm running BFG g-force T/A drag radials. I didn't even burn out on them in the water box...should I ? Here's what I got for my first 1/4 mile time at the drag strip...with my completely stock internals, full interior, Drag 3 gsr...i didn't even have that good of traction with the bfg's i guess i gas it to much or something, It didn't hook up at all in first gear the niddle just stayed at 7,600. When it finally did hook up i hit the second step rev limit and shifted to second. I two steped at 5,200 and slipped the clutch
reaction: .717
I1: 2.282
I2: 6.108
I3: 9.155
(I3) MPH: 82.599
I4: .000
E.T: 13.896
MPH: 105.580
Old Oct 22, 2002 | 06:02 PM
1 2 NV's Avatar
Default Re: first time at the 1320.... (CM-R)
reaction: .717
I1: 2.282
I2: 6.108
I3: 9.155
(I3) MPH: 82.599
I4: .000
E.T: 13.896
MPH: 105.580
well normally i come up with something along the lines of u cant drive, but in this case everything is adding up. 2.2 isnt that bad of a 60 ft, but its definitely comin after the 60 ft mark to the 1/8th mark. u need to MODULATE throttle, instead of ***** out u need to lay off it until it fully hooks. ur 1/8th mile time says low 14s, the MPH however shows low 13s upper 12s. ur 1/4 mile time says "u suck" (haha jk) and the MPH states lower 13s upper 12s also. after the 60 ft mark concentrate on wheelspin.
Old Oct 22, 2002 | 07:59 PM
CM-R's Avatar
Default Re: first time at the 1320.... (hondaatwsu)
lol...thanks for the "Encouragement". Now i know where my car should be at when i get more and more and more practice which i need. I'm going to be getting some M/H 20x6x14 slicks to help with my 60fts...thanks for the info
Old Oct 22, 2002 | 08:31 PM
krazn's Avatar
nice 0-60. times look good to me.
Old Oct 23, 2002 | 12:10 PM
raene's Avatar
Yes, your MPH indicates lower ETs but your drag radials are holding you back from the launch... getting slicks would, I think, drop you into the low 13s/high 12s. Like hondaatwsu said, you need to really modulate throttle in that first 1/8th, tirespin all through a gear is BAD.
Old Oct 23, 2002 | 01:07 PM
CM-R's Avatar
Default Re: first time at the 1320.... (raene)
I'll try the madulation technique when i go back with slicks....After the 13.8 run i looked at the tires and they looked melted almost and those things were brand new
Old Oct 23, 2002 | 04:30 PM
ExospeedAMcrx's Avatar
slicks would be a good step up, but if you are investing in brand new slicks, I'd step up to a bigger slick. at least a 22x8x13. you'll overpower the 20x8x14's pretty soon and with the 22x8x13's, those will last longer as you go up in HP, its a more diverse slick for the 180-300HP range.
Old Oct 23, 2002 | 06:35 PM
CM-R's Avatar
Default Re: first time at the 1320.... (exospeedAMcrx)
i would go with the 13 inch rim, but since i have a dc2 gsr i can't put 13's on because of my rotor clearence correct?
jdmcoop
Dec 12, 2008 07:27 PM
Sliced Beard
Honda Motorcycles
27
May 2, 2008 09:01 PM
RACEPAK
Dec 18, 2005 08:15 AM
TravSi
Aug 11, 2003 01:50 AM
CM-R
Oct 14, 2002 10:02 AM
