First steps for a B16A2
Old Jul 30, 2005 | 12:34 PM
delectric's Avatar
Default First steps for a B16A2
Hellooo, i'm writing from Spain, Canary Island exactly. My english is not very good but i will try xDD. I have a 2000, 1.6 Vtec Civic, B16A2 equiped. I'm thinking in big modification of it. I'm thinking in a Turbo Kit but at finals, first make all the thinks that done my B16A2 live many years Block modifications,Pistons,etc(I don't know surely).Then is my question, what can i do before turbo installation? Valve Train, Manifolds, Electronics i don't know what are the better steps.
Thanks anyway and sorry for my english.
Please I need help
Old Jul 30, 2005 | 02:44 PM
delectric's Avatar
Default Re: First steps for a B16A2 (delectric)
Please I need help
Old Jul 30, 2005 | 04:26 PM
hybridsol's Avatar
You don't "need" to do anything to the motor to turbocharge it, up to about 8-10 psi, as long as the compresion is good.
You will need to modify the ECU. You cannot modify the one in your car. The best way to do this is to use an OBD1 ECU (P28 or P72 Honda part) and re-chip it with Hondata or Uberdata -OR- you could buy a AEM Unit... either way you'll need to modify your wiring harness (ther are kits for this)
After that, everything else is either bolt on, or custom made, depending on your plans and $$$
Remeber you need to add more fuel (bigger injectors and ECU changes) and reduce idnition timing when adding boost.
Good luck...
Additional boost will require pistons, rods, and possibly block sleeves.
Old Jul 31, 2005 | 06:13 PM
delectric's Avatar
Default Re: First steps for a B16A2 (hybridsol)
Many thanks for your help, Now is time to start in it. About the turbo kit i was thinking in Greddy TDO5H-18G accompanied whit Intercooler and EvoTT Exhaust system or HKS ones.
What manifolds do you recomend me?(For turbo use at first and a possible wet nitrous system in the future)
Cams and Valve Springs is a good option after turbo instalation?(I was thinking in type-r ones or a skun2 turbo cams)
Thanks for all .Ciaoo
Old Aug 1, 2005 | 05:17 AM
delectric's Avatar
Anyones can advise me, please?
Old Aug 1, 2005 | 08:54 AM
NotUrAvgSi's Avatar
supertech springs and retainers itr cams full-race exhaust manifold
Old Aug 1, 2005 | 05:52 PM
delectric's Avatar
Default Re: (NotUrAvgSi)
Wy ITR cams? Make good results with turbo?
Old Aug 2, 2005 | 01:48 AM
abnaasefmb's Avatar
Default Re: (delectric)
there is this thing in the upper right hand corner called the “search” button. You click on it and type in what your looking for and read the results. If at some point you find a topic that has not been covered a thousand times, then you post your question. Don’t just surrender at the first sign of defeat. you have to persevere, and “STAY THE COURSE”! good luck.
https://honda-tech.com/zerosearchall your answers are here
Old Aug 4, 2005 | 01:15 PM
delectric's Avatar
Default Re: (abnaasefmb)
How can I get a pair of ITR cams? Here is difficult to localate.
xlasianizelx
Sep 16, 2008 02:01 PM
steebi
Aug 10, 2008 01:00 PM
mtkhalid
Mar 19, 2007 06:53 PM
jonbouy
Nov 9, 2005 01:34 PM
delectric
Jul 30, 2005 04:25 AM
