First 11 sec Vitara setup
Old Feb 2, 2006 | 06:20 AM
fjt's Avatar
fjt
Default First 11 sec Vitara setup
Well for those who were waiting on an 11 sec or 300+ whp setup with vitara pistons..I am pleased to announce that someone i know, who's been running these pistons for over 3 years just ran last night at the track an 11.9 @ 117mph on a 2700lbs Civic DX coupe(driver weights 260lbs). His 60ft was 1.89 on slicks(24 X 8 X 13"). Seems like he will need bigger slicks cause the car still let the slicks loose all over the 1/4 run.
He dynoed 312whp and 300lbs/ft like a month ago.
The car is a D16y7 motor and the car still has A/C and P/S. The car retains its OBDII ECU and runs tuned just on an APEX AFC
The car was ran complete with all its seats and interior..Full exhaust too.
His setup is:
D16y7 block, D16Y7 head
Vitara pistons
Block guard
ARP Head studs.
D16Y7 tranny
Cluutchmasters STage 3 clutch
Head is ported and polished
Y8 Intake manifold(Also ported and polished)
Log manifold, T3 off a Volvo(.42/.48)...yeah its a freaking small turbo..running around 24PSI
Presicion 500hp intercooler
Tial WG
Greddy BOV
620cc Injectors
2.5"Downpipe and exhaust
255lph fuel pump
Aeromotive FPR
just letting you guys know.
My car should be next to be running 11's and 300+ whp...soooooon
Old Feb 2, 2006 | 06:38 AM
Brain3208's Avatar
Default Re: First 11 sec Vitara setup (fjt)
What rods was he using on that setup? seems a bit high for that setup especially the AFC HACK since you only get maybe 6-10psi safely before the engine poops.
call BS till we see a slip.
If it is indeed that quick than
Brain
Old Feb 2, 2006 | 06:42 AM
splitime's Avatar
Default Re: First 11 sec Vitara setup (Brain3208)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brain3208 &raquo;</TD></TR><TR><TD CLASS="quote">What rods was he using on that setup? seems a bit high for that setup especially the AFC HACK since you only get maybe 6-10psi safely before the engine poops.
Brain</TD></TR></TABLE>
Lol... that isn't true about the hack. Its just that their are much safer ways to run. Remember that the compression of that motor is very low... so the ignition advance issue with the hack is sort of nullified... and he's pumping alot of fuel at it.
Knowing FJT, if his buddy still has the slip... he'll post it up though... no reason for him not to. Heh... if I have my way, i'll be close to that this year with my new kit.
Old Feb 2, 2006 | 06:43 AM
1boostedcivic's Avatar
that is downright nuts.
1. 312 whp 300lbs torque with that turbo and the afc
2. no vtec
3. 2700lbs
thats unbelievable
Old Feb 2, 2006 | 06:49 AM
93supercoupe's Avatar
Default Re: First 11 sec Vitara setup (1boostedcivic)
I agree, and a moderate 60ft.
Old Feb 2, 2006 | 07:10 AM
fjt's Avatar
fjt
i will try to get the slip.
Everyone hates on the AFC, everyone hates on vitaras, everyone hates on everything that "seems" impossible..
out here we always find the way to make things work..Probably if you come here you will find tons of unveliable fast cars that runs with AFC/VAFC or other arcaic/old methods..
I have always said that for some reason, and i believe that is due to the facts that these pistons like timing, they always net good torque numbers.. Look at my setup..266whp and 240lbs/ft
Old Feb 2, 2006 | 07:14 AM
rainmanef's Avatar
You have any prove of this FJT?
Old Feb 2, 2006 | 07:16 AM
fjt's Avatar
fjt
Default Re: (rainmanef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rainmanef &raquo;</TD></TR><TR><TD CLASS="quote">You have any prove of this FJT?</TD></TR></TABLE>
Working on it...
trying to get the slips from the owner of the car.
Old Feb 2, 2006 | 07:18 AM
Turbo-charged's Avatar
Default Re: (rota92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 &raquo;</TD></TR><TR><TD CLASS="quote">I dont think its the slick thats letting loose, lots of us run a 24.5x8.5x13 with no problems at all, the guys with 500 HP run them, and I plan too for 550+ so its likely a suspension issue or alignment etc.
Though!</TD></TR></TABLE>
john F ran 9.6x @ 156'ish on my 24.5's.....its not the slicks
Old Feb 2, 2006 | 07:53 AM
bluemax189's Avatar
Default Re: (Turbo-charged)
im still wondering the rods he was using.
Old Feb 2, 2006 | 08:00 AM
yellowturbo's Avatar
Default Re: (fjt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fjt &raquo;</TD></TR><TR><TD CLASS="quote">i will try to get the slip.
I have always said that for some reason, and i believe that is due to the facts that these pistons like timing, they always net good torque numbers.. Look at my setup..266whp and 240lbs/ft</TD></TR></TABLE>
these pistons like timing ??? what its supposed to mean ?? They like detonation ??
T3T495GSR's Avatar
Default Re: (bluemax189)
Hi, I dont mean to steal this thread but I was wondering what the trick is getting your torque numbers so close to the Whp .
For instance, I have 293whp and 193TQ @12psi tuned conservatively
b16 block gsr head,
How do i get my torque higher? is it the turbo? or just the tuning? thanks
Old Feb 2, 2006 | 08:01 AM
splitime's Avatar
Default Re: (yellowturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowturbo &raquo;</TD></TR><TR><TD CLASS="quote">these pistons like timing ??? what its supposed to mean ?? They like detonation ?? </TD></TR></TABLE>
Low comp = easier to run more timing. Just like low comp usually = ability to run more boost. It just decreases the detonation threshold some... nothing really crazy to it.
Old Feb 2, 2006 | 08:45 AM
z6's Avatar
z6
Default Re: (T3T495GSR)
the only reason they make closer tq and hp #s is because they rev lower...combine that with the smaller turbos used and you get big tq
Old Feb 2, 2006 | 08:49 AM
z6's Avatar
z6
Default Re: (splitime)
these pistons like timing ??? what its supposed to mean ?? They like detonation ?? </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime &raquo;</TD></TR><TR><TD CLASS="quote">
Low comp = easier to run more timing. Just like low comp usually = ability to run more boost. It just decreases the detonation threshold some... nothing really crazy to it.</TD></TR></TABLE>owned
Old Feb 2, 2006 | 08:57 AM
fjt's Avatar
fjt
Well i gues you cant run 24* of total timing at 18PSI on your setup without a sign of detonation and on pump gas with your setup...lol
thats what it means that they like timing..
Old Feb 2, 2006 | 09:03 AM
T3T495GSR's Avatar
Default Re: (z6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6 &raquo;</TD></TR><TR><TD CLASS="quote">the only reason they make closer tq and hp #s is because they rev lower...combine that with the smaller turbos used and you get big tq</TD></TR></TABLE>
Well I guess I cant complain then since LAAAAGG is tractions best friend
Old Feb 2, 2006 | 09:14 AM
notoriousB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fjt &raquo;</TD></TR><TR><TD CLASS="quote">runs tuned just on an APEX AFC
620cc Injectors
how in the world is he running the AFC hack at 24 psi with 620cc injectors?
Old Feb 2, 2006 | 09:29 AM
99lspwr's Avatar
Default Re: First 11 sec Vitara setup (notoriousB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB &raquo;</TD></TR><TR><TD CLASS="quote">
I would like to know this too...
Old Feb 2, 2006 | 09:35 AM
fjt's Avatar
fjt
why... you thought it was impossible or is it because everyone else says it is not possible?
Old Feb 2, 2006 | 09:46 AM
btotherizzle's Avatar
there is no way this is true. this car with the over weight driver should only be good for 13.0.
Old Feb 2, 2006 | 09:47 AM
Semnos's Avatar
D16's have a long stroke..good for making torque..and not revving it too high.
b16's have a very short stroke...makes a lot less torque, but good for revving it high...making a lot of hp but not much torque.
Old Feb 2, 2006 | 09:56 AM
ELSpool's Avatar
I think the coupe is lighter than your guessing because my 4dr weighs about 2700 without driver, and I ran a pile of 12.2's at the same mph as him with 50 more whp in a D16.
Eitherway, impressive on an AFC and pump gas, thats *****!
Old Feb 2, 2006 | 10:15 AM
Boosted Chemist's Avatar
how does the car idle? i know the afc doesnt goe below 50 percent and with 450 it was rich at -40% on my old setup
Old Feb 2, 2006 | 10:16 AM
NeOh 2ning's Avatar
Hi guys im NeOh im FJT's tuner and mechanic and friend of the guy that ran 11.9 yesterday, i will tell you i have cars running 720 injectors on a VAFC and no drivability problems i wiil get the slip and posted for all you non believers if it cant be done leave it to us in Puerto Rico i guarantee we can do it take care
