finally ran the LS-T Hatch :(
Old Mar 5, 2004 | 11:15 PM
GDM Z28's Avatar
Default finally ran the LS-T Hatch :(
Well i made it to the track tonight and i got to run the car 3 times. it wasnt as good as i wanted but its ok i suck at driving on the track. the 2nd run was against an Evo 8 and i beat him by .6 or so . Last run was against a SVT cobra with exhaust and work done, he didnt start pulling till the end. i also have a messed up drovers side axle so ive bee braking axles l8ly so im kinda hard to push it all the way so i wasnt slamming gears. do you guys know what i should do to improve my times and hit a 12.9? i dynoed 242whp and 221wtq. well enough BS heres the slips...
run #2:
60ft.....2.394
330.....6.130
1/8th.....9.062
MPH.....84.15
1000.....11.570
1/4.....13.6
MPH.....107
Last run of the night
60ft.....2.523
330.....6.221
1/8th.....9.132
MPH.....84.57
1000.....11.627
1/4.....13.7
MPH.....108.5
Old Mar 5, 2004 | 11:25 PM
tyflip2's Avatar
Default Re: finally ran the LS-T Hatch :( (civicflnum1)
2.5 is not a very good 60ft time at all. throw some slicks on that and get that down to a 2.1 or so and you should easily get a 12.9
Old Mar 5, 2004 | 11:26 PM
GDM Z28's Avatar
Default Re: finally ran the LS-T Hatch :( (tyflip2)
that would be fun (running slicks) but im on a stock clutch
Old Mar 5, 2004 | 11:38 PM
Mr. Softee's Avatar
109mph
Old Mar 6, 2004 | 04:20 AM
BoostedsiR's Avatar
Default Re: finally ran the LS-T Hatch :( (94goldjungsr)
your trap speed is pretty good but the question is driving. you got to improve that 60 ft
Old Mar 6, 2004 | 05:31 AM
Burke's Avatar
Banned
Default Re: finally ran the LS-T Hatch :( (BoostedsiR)
i was running mid 12's on slicks trapping 109
you can do it!!
Old Mar 6, 2004 | 07:15 AM
GDM Z28's Avatar
Default Re: finally ran the LS-T Hatch :( (Burke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burke &raquo;</TD></TR><TR><TD CLASS="quote">i was running mid 12's on slicks trapping 109
you can do it!!</TD></TR></TABLE>
i know i wish it was cold again. i wana hit 12's sooooo bad lol. but i hate moroso's track. the cool thing is when i went 13.6 i smacked up and evo. that was priceless
Old Mar 6, 2004 | 11:14 AM
SIK IN DA HED's Avatar
New User
well... what do you expect? your turbo setup is good to go... but other parts in your car are F'ed up. get a new clutch. get your axle repaired/replaced. get some slicks or drag radials. then youll see what you should be runnin.
Old Mar 6, 2004 | 12:46 PM
1.8t's Avatar
Default Re: finally ran the LS-T Hatch :( (SIK IN DA HED)
Sounds like me.....I ran a 13.8@111mph on my stock internal LS-T hatch. Damn trap would be better if I could make the freaking thing hook up more in second gear.....second gear wheelspin is absolutely rediculous
Old Mar 6, 2004 | 01:25 PM
I Like Boost's Avatar
Default Re: finally ran the LS-T Hatch :( (1.8t)
check your motor mounts also. mine were broke in 2 pieces and i kept breaking axles and running shitty times at the track with my integra
Old Mar 6, 2004 | 02:44 PM
fsp31's Avatar
Default Re: finally ran the LS-T Hatch :( (I Like Boost)
What's an Evo 8 running 14's for?
Old Mar 6, 2004 | 02:46 PM
drvfast's Avatar
what are you running for fuel managment?
Old Mar 6, 2004 | 02:55 PM
greekspeed's Avatar
Default Re: finally ran the LS-T Hatch :( (airshifta)
it looks like the only thing thats keeping u from getting the 12's, is driving and traction., and u will need an aftermarket clutch probably to push ur car harder and not have any slipage.
those trap speeds are high enough for 12s
Old Mar 6, 2004 | 03:17 PM
VTC_CiViC's Avatar
Default Re: finally ran the LS-T Hatch :( (greekspeed)
Fix that mount situation and borrow my DR's Trent, you'll be in the 12's in no time
Old Mar 6, 2004 | 03:36 PM
typer rick's Avatar
Default Re: finally ran the LS-T Hatch :( (VTC_CiViC)
That's some good times. How much boost were you runing.
Old Mar 6, 2004 | 07:01 PM
GDM Z28's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by airshifta &raquo;</TD></TR><TR><TD CLASS="quote">what are you running for fuel managment?</TD></TR></TABLE>
uberdata, tuned by vtc_civic
BTW my moutns are fine im just missing the bolts that hold the mount to the block on the drivers side. ill fix that tomorrow. BTW i was told the clutch was stock but it hasnt slipt on me once so im not sure.
P/S- this was on 10 psi
Old Mar 6, 2004 | 09:24 PM
Mr. Softee's Avatar
did you use my tune? how much pwr did you put down?
Old Mar 6, 2004 | 10:43 PM
GDM Z28's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">did you use my tune? how much pwr did you put down?</TD></TR></TABLE>
no me and dave did our own tune. i put down 242whp and 221wtq. we could of made more but i was scared to have dave add timing. even though he says its really conservative right now.
Old Mar 6, 2004 | 10:48 PM
Mr. Softee's Avatar
what turbo/exhaust setup
Jkan2001's Avatar
I'm guessing you don't have LSD? I think a set of slicks would definetely help the cause cause it sounds like you're spinning or hopping out of the hole to get a bad ET and great trap.
I managed to pull consistent 1.8 60 foots in my 00 ex coupe w/o LSD and i only made 176/173 to run a 8.52 in the 1/8 mile. The small E.T drags and light 14" wheels definetely did the trick
Old Mar 6, 2004 | 11:31 PM
GDM Z28's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">what turbo/exhaust setup</TD></TR></TABLE>
T3 50 trim with a .48 on the ext. and i have a 2.5" DP to a 2.25" test pipe( ) to a 3" mandral bent catback w/ no muffler
the car pulls hard, ask dave how my tail lights look
Old Mar 7, 2004 | 01:16 AM
EG*MonKEY's Avatar
sup buDDie......it was a str8 nite..yea like everyone says ...fix the basic maintnence parts on your car..and practice launching a few more times and youll be good...but ill hope to own your .50 trim with my .60 trim lol chop chop
Old Mar 7, 2004 | 07:43 AM
91tegrals's Avatar
hows youre car sounds with out a muffler..
Old Mar 7, 2004 | 08:41 AM
GDM Z28's Avatar
Default Re: (91tegrals)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91tegrals &raquo;</TD></TR><TR><TD CLASS="quote">hows youre car sounds with out a muffler..</TD></TR></TABLE>
sounds fine. nice and mean. its quieter then having a mufler i think/
Old Mar 7, 2004 | 12:45 PM
Deluzional's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicflnum1 &raquo;</TD></TR><TR><TD CLASS="quote">
thats a huge bottleneck you have there, redo that **** too
