Finally... I'm done!!!
Old Jul 23, 2004 | 01:35 PM
  #26
FOrSfEd's Avatar
Default Re: Finally... I'm done!!! (9psiTurboSI)
I think the hp you are at now is pretty good. Thats easy low 12 sec 1320's with drag radials. And 350 on stock isn't bad.
Old Jul 23, 2004 | 01:43 PM
  #27
IMSTOCK's Avatar
U do not need an exsternal fuel pump.
Old Jul 23, 2004 | 01:57 PM
  #28
G
sh!t happens.
Default Re: (IMSTOCK)
duuuuuuuuuuuuuuuuuuuuuuuuhhhhhhhhhhhhhh
Modified by G"UNIT at 3:44 PM 7/23/2004
Old Jul 23, 2004 | 02:39 PM
  #29
Mase's Avatar
Default Re: (G"UNIT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G"UNIT &raquo;</TD></TR><TR><TD CLASS="quote">350 is good for stock.. </TD></TR></TABLE>
its not stock.
Old Jul 23, 2004 | 02:42 PM
  #30
G
sh!t happens.
Default Re: (Mase)
on ME...lol
Old Jul 23, 2004 | 02:46 PM
  #31
MachAF's Avatar
Default Re: Finally... I'm done!!! (Liltrix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Liltrix &raquo;</TD></TR><TR><TD CLASS="quote">IMO the CR 8.8:1 is a little on the low side - more boost = more heat, so now you are getting more heat and more lag, not so good; furthermore with that set up and the more boost you plan to run, you will need at least 720cc RCs. Hey guy do it properly from the beginning.
1. Sleve the block - it is great insurance.
2. You need 9.0:1 CR on those pistons - forget lag before high boost, you will loose the race as soon as it begins.
3. Get RCs 720 or even bigger.
4. Get an Aeromotive external pump and filter
5. Get proper tuning - you have a great stand alone.
look for about 475-525 WHP.
6. Have fun safely ie at the track.
7. Try to get 16" wheels the rolling radius helps
Colin</TD></TR></TABLE>
Show me your reasoning (Ie. dyno plots) that 8.8:1 compression is going to make a difference in turbo spool time.
Old Jul 23, 2004 | 07:32 PM
  #32
Liltrix's Avatar
Default Re: Finally... I'm done!!! (MachAF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MachAF &raquo;</TD></TR><TR><TD CLASS="quote">
As far as I know (and I dont know everything)higher compression helps boost response, I have seen that with my own set up, I actually went from a 8.8:1 to a 10.0:1 and I noticed an improvement in boost response. I do not have dyno plots to back up what I am saying, but if you are going to use dyno plots as the sole "measuring stick" then all other variables like the day's temp etc must be identical. I have felt a noticable difference with my car when I went up with higher compression. Furthermore, I was giving my own opinion, if you noticed the post it started with "IMO" plus thats not the only comment I made regarding the original post, I mentioned the injectors, fuel, sleeving, proper tuning, safety and 16" wheels.
Old Jul 23, 2004 | 07:42 PM
  #33
Liltrix's Avatar
You dont drag race? you do circuit then?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9psiTurboSI &raquo;</TD></TR><TR><TD CLASS="quote">
Why do I need 475-525hp when I don't drag race </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9psiTurboSI &raquo;</TD></TR><TR><TD CLASS="quote">
I went with 8.8:1cr for 2 reason... so I can run more boost safer and I it lags alittle but once at 4500rpm+ it just pulls like a bicth and even at 340hp on the street im not spinning tire like crazy 1st-3rd, but i dont race people on the streets, just on the track and on the track im always at high rpm so it works out good </TD></TR></TABLE>
Old Jul 23, 2004 | 10:01 PM
  #34
m R g S r's Avatar
Maybe he doesn't want 525hp like everyone else?
Old Jul 25, 2004 | 09:01 PM
  #35
11psiTurboSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Liltrix &raquo;</TD></TR><TR><TD CLASS="quote">You dont drag race? you do circuit then?
Yea, I don't drag race... just auto-x and road race (circuit)
Old Jul 25, 2004 | 09:25 PM
  #36
Money_B's Avatar
Looks good.
Old Jul 26, 2004 | 08:58 AM
  #37
https://honda-tech.com/zerothread?id=922152
Old Jul 26, 2004 | 08:59 PM
  #38
SiRkid's Avatar
beautiful. wish my car had worked out well
99SlammedCivic
Nov 15, 2008 12:40 PM
s2kfromhell
Honda S2000
47
Aug 27, 2008 04:32 AM
manifoldmiketyson
Welding / Fabrication
21
Feb 22, 2008 05:48 PM
Drizzo
Jun 15, 2005 09:25 PM
